04-04-2020, 16:19 | #19 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | @ solgeo This global forum also father's of gsm industry, Really I cannot understand here you have done Which kind of comments against another members ? Code: And those who advise let them think what kind of Kirin it is! I never expected this type of neglected comments from you. Just be pollinate & do respected each other members hopefully you will be respected.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following 3 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
04-04-2020, 16:21 | #20 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Sir My problem is still there i have Dc Phoenix,for servicing huawei please i need exact files and guide for reviving m phone Thanks |
04-04-2020, 16:34 | #21 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | STK-LGRP3-OVS 9.0.1.170, Only for the downgrade version reason you got this Bricked problem. So you have need to be find out / collect the version of ''STK-L21M 10.0.0.193(C185E3R2P2)'' APP offline full package firmware, which version already have inside the phone. Hopefully you can flash the phone with blank fast-boot mode condition, with DC-Phoenix can be makes upgrade mode for flashing.
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
04-04-2020, 22:47 | #22 (permalink) | |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Quote:
Yes, problems and solutions are discussed here. I can explain! Or do you tell me which programmer is doing 710 980 or 990 Kirin now ?? P.S. The user has a jammed boot, all that is possible is to restore fastboot, but at the same time it will be further FRP LOCK PHONE LOCK Recovery and Erecovery after overloading the phone will not work. | |
The Following User Says Thank You to solgeo For This Useful Post: |
04-05-2020, 02:17 | #23 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Yes of-course you can explain here nicely with sweet-able word, when it's not now exist for 710 / 980 or 990 Kirin properly solution. That's mean you cannot exhaustion / Contempt others members by this type of word, ''And those who advise let them think what kind of Kirin it is!'' Anyway, let's move on to positive thinking and forget about Fierce. Best regard
04-06-2020, 12:44 | #24 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | sir please canu tell the exact file name that i can flash to revive my phone now i cannot even flash bootloader in Update Oem info TAB Stage 2 Error |
04-06-2020, 15:10 | #25 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | Hi, You can try with this, STK-LX1 Dead Boot Repair Without Lost IMEI And OEM.zip credit goes to Uploader.
04-06-2020, 16:44 | #26 (permalink) | |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Quote:
i have downloaded these files it requires Octoplus Huawei which i dont have can this board be flashed with IDT | |
04-06-2020, 17:35 | #27 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,108 | yes It's can be flash via IDT. Sent from my EML-L09 using Tapatalk Pro
04-06-2020, 18:06 | #29 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: 20200406-10:04:32 usb1:Start downloading with VCom! 20200406-10:04:32 usb1:Load DownLoadBoot Version 2.0.0.9 20200406-10:04:33 usb1:Opening COM4 Success 20200406-10:04:33 usb1:download mode enter:31 20200406-10:04:33 usb1:Downloading xloader begin. 20200406-10:04:33 usb1:Writing xloader... 20200406-10:04:33 usb1:Write delay = 3000 ms. 20200406-10:04:36 usb1:Download xloader end. 20200406-10:04:36 usb1:download mode enter:0 20200406-10:04:36 usb1:Downloading uce begin. 20200406-10:04:37 usb1:Writing uce... 20200406-10:04:37 usb1:Write delay = 3000 ms. 20200406-10:04:40 usb1:Download uce end. 20200406-10:04:40 usb1:download mode enter:0 20200406-10:04:40 usb1:Downloading fastboot begin. 20200406-10:04:58 usb1:Writing fastboot... 20200406-10:04:58 usb1:Write delay = 3000 ms. 20200406-10:05:01 usb1:Download fastboot end. 20200406-10:05:01 usb1:VCom download successfully. 20200406-10:05:07 usb1:Continue downloading with Fastboot! 20200406-10:05:07 usb1:nPosID = 1. 20200406-10:05:07 usb1:Load DownLoadFastBoot Version 2.0.0.9 20200406-10:05:07 usb1:Loading image files and downloading image... 20200406-10:05:07 usb1:OKAY471859200 20200406-10:05:07 usb1:sending 'huawei_crc_check' (0 KB) 20200406-10:05:07 usb1:OKAY 20200406-10:05:07 usb1:writing 'huawei_crc_check' 20200406-10:05:07 usb1:FAILCommand not allowed 20200406-10:05:07 usb1:sending 'huawei_crc_check' (0 KB) 20200406-10:05:07 usb1:OKAY 20200406-10:05:07 usb1:writing 'huawei_crc_check' 20200406-10:05:07 usb1:FAILCommand not allowed 20200406-10:05:07 usb1:sending 'huawei_crc_check' (0 KB) 20200406-10:05:07 usb1:OKAY 20200406-10:05:07 usb1:writing 'huawei_crc_check' 20200406-10:05:07 usb1:FAILCommand not allowed 20200406-10:05:08 usb1:Midway download fail, disconnected 20200406-10:05:08 FAIL (35 s). Error (39) |
04-06-2020, 18:11 | #30 (permalink) |
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | Code: 4/6/2020 10:10:48 AM Starting to write device in FASTBOOT mode... File size: 4,003,234,052 bytes Current version(BASE_VER): STK-LGRP3-OVS 10.0.0.1 Looking for a device in fastboot mode Device found: TMF4C19621008098 Getting IMEI... Getting build number... Getting model ... Getting battery state... Getting backdoor info... Getting lock state info... Getting lock boot info... Build number: :STK-L21M 10.0.0.193(C185E3R2P2) Model: STK-L21 Vendor/Country: hw/meafnaf Battery state: 0 OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Device with unsupported security patch Process identifier:23800334 Erasing ver .. . Writing BASE_VERLIST partition BASE_VERLIST partition update :FAIL Command not allowed Device with unsupported security patch 4/6/2020 10:11:00 AM Writing device finished - INCOMPLETE |
