LCD Refurbish All things related to LCD / Screen refurbish and repair |
03-14-2016, 07:50 | #1 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2545607 Status: Offline Thanks Meter: 0 | Ak laminating machine issues I have the AK 2 in 1 OCA laminating machine. When I run the machine it is set for 10 mins. The pressure in the chamber is set for 90 PSI. After a few mins to pressure goes down to 60-70 psi and then down to 40 psi after about 5 mins. I talked with the manifactuior and they said this is normal. I find that hard to believe, i figure the machine should hold its constant pressure for the whole 10 mins. Has anyone else had this issue at all? if you have a different machine what pressure do you run it at and does it hold that pressure constant? thanks |
03-20-2016, 03:50 | #2 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2463290 Status: Offline Thanks Meter: 0 | Hi I usualy run my machine at around 50 psi and it works fine, laminating time 280 seconds, does yours have a knob at the back or side to adjust the pressure? My prodecure which seeems to work is to turn the machine on, and press laminator with the door still open slightly, then wait for the temperature to rise, then i put the lcd in and close the door and hit start, then i monitor the pressure gauge and adjust it accordingly, it always maintains the pressure i set it to |
11-30-2016, 16:21 | #3 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2654250 Status: Offline Thanks Meter: 0 | Hello guys, can you give me more review about this machines? I mean to buy machines like this.. I looking right this mackines AK 2 in 1 but I do not know is the machines realy good. Do you have some bubles problem? |
