Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 04-26-2015, 17:30   #31 (permalink)
Member: 523004
these machines:tbk or mag ,automatic ,No Bubble No Molds 5 in 1 OCA Vacuum Laminator Laminating Machine LCD Screen Repair Equipment KO-MAG,someone has used them, are reliable, and these machines, they have problems of bubbles? help do not know what to buy I have little space in your home
Old 04-26-2015, 18:05   #32 (permalink)
Member: 2204208
Thanks Meter: 2
i have the ko macine they work good for me but they dont remove the bubbles 100% luck for me i have bubble remove machine :-) any one use the vacouum lcd seprator?
The Following User Says Thank You to benistinc For This Useful Post:
Old 04-26-2015, 18:17   #33 (permalink)
Member: 2146354
Thanks Meter: 21
I use the vaccum Lcd seperator.
But
I do not use the automatic vaccum glass seperator. I dont believe in that machine. I believe its better to do manual seperation with your hands. the automatic machine has too many factors to set. Very easy to break pcd on it and tear polarizer.
The Following User Says Thank You to cellularman89 For This Useful Post:
Old 04-26-2015, 18:31   #34 (permalink)
Member: 523004
ko which machine you feel comfortable? that model?
Old 04-26-2015, 18:43   #35 (permalink)
Member: 523004
one other issue with the machine ko, then uses remove bubbles, perfect after I there are always problems of bubbles that everyone is talking about?
Also, because I have to buy, and I would not spend $ 2,000, then to have problems after bubbles
please help to buy a machine that has no problems, some advice from some model that you have?
Old 04-26-2015, 19:20   #36 (permalink)
Member: 523004
I also agree machinery automatic separator, can 'do a lot of damage
Old 04-26-2015, 22:31   #37 (permalink)
Member: 523004
please help me to buy the right machine
Old 04-26-2015, 22:35   #38 (permalink)
Member: 2204208
Thanks Meter: 2
some time the lcd slip in the vacoum seprstor any advise?
Old 04-26-2015, 22:50   #39 (permalink)
Member: 523004
not 'clear what you asked
Old 04-26-2015, 23:02   #40 (permalink)
Member: 523004
please help me,that model and what brand do you recommend
Old 04-26-2015, 23:43   #41 (permalink)
Member: 523004
benistinc,I know you recommend?
Old 04-27-2015, 00:23   #42 (permalink)
Member: 523004
Old 04-27-2015, 14:27   #43 (permalink)
Member: 2204208
Thanks Meter: 2
you need it for youer shop or you whant to sell them?
i what i ask is some tip's for the vacouum seprator the lcd some time slip form the hot plate (if he crack) any help for this problam?
Old 04-27-2015, 22:17   #44 (permalink)
Member: 15149
Thanks Meter: 61
guys i had some of problems like you with oca and i solved, problem usualy when u installing oca on the lcd or when u laminate the screen is down becuase the part of the tape from back of the lcd left in the frame then u need to put something under lcd inside mould to laminate good its shouldnt be almost nothing bubbles if anyone have more questions please contact me on skype
Old 04-27-2015, 22:30   #45 (permalink)
Member: 2204208
Thanks Meter: 2
i have some prablom when i remove the polroizer in the iphone 5 when i remove the glue some of the adhesive remover get in the backlight how you do it
Page generated in 0.24195 seconds with 9 queries
