LCD Refurbish All things related to LCD / Screen refurbish and repair |
04-26-2015, 17:30 | #31 (permalink) |
Junior Member Join Date: Jun 2007
Member: 523004 Status: Offline Thanks Meter: 0 | |
04-26-2015, 18:05 | #32 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2204208 Status: Offline Thanks Meter: 2 | i have the ko macine they work good for me but they dont remove the bubbles 100% luck for me i have bubble remove machine :-) any one use the vacouum lcd seprator? |
The Following User Says Thank You to benistinc For This Useful Post: |
04-26-2015, 18:17 | #33 (permalink) |
Insane Poster Join Date: Mar 2014
Member: 2146354 Status: Offline Thanks Meter: 21 | I use the vaccum Lcd seperator. But I do not use the automatic vaccum glass seperator. I dont believe in that machine. I believe its better to do manual seperation with your hands. the automatic machine has too many factors to set. Very easy to break pcd on it and tear polarizer. |
The Following User Says Thank You to cellularman89 For This Useful Post: |
04-26-2015, 18:43 | #35 (permalink) |
Member: 523004 Status: Offline Thanks Meter: 0 | one other issue with the machine ko, then uses remove bubbles, perfect after I there are always problems of bubbles that everyone is talking about? Also, because I have to buy, and I would not spend $ 2,000, then to have problems after bubbles please help to buy a machine that has no problems, some advice from some model that you have? |
04-27-2015, 14:27 | #43 (permalink) |
Member: 2204208 Status: Offline Thanks Meter: 2 | you need it for youer shop or you whant to sell them? i what i ask is some tip's for the vacouum seprator the lcd some time slip form the hot plate (if he crack) any help for this problam? |
04-27-2015, 22:17 | #44 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Cyprus Age: 42
Member: 15149 Status: Offline Thanks Meter: 61 | guys i had some of problems like you with oca and i solved, problem usualy when u installing oca on the lcd or when u laminate the screen is down becuase the part of the tape from back of the lcd left in the frame then u need to put something under lcd inside mould to laminate good its shouldnt be almost nothing bubbles if anyone have more questions please contact me on skype |
