Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 05-02-2015, 02:09   #61 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
Originally Posted by maxevita View Post
you can tell where you buy it?
Buy what????????????
Specify your question please.
Old 05-02-2015, 07:40   #62 (permalink)
Member: 2329506
Thanks Meter: 5
i hv same problem i m appreciate if anybody can help.
Old 05-02-2015, 21:25   #63 (permalink)
Member: 2146354
Thanks Meter: 21
pm me..................
Last edited by chand_gee; 02-09-2017 at 02:42. Reason: link going to external website
Old 05-02-2015, 21:27   #64 (permalink)
Member: 2146354
Thanks Meter: 21
He's talking about oca with loca in it. After autoclave your supposed to put in uv light to prevent the bubbles from returning.
Old 05-02-2015, 21:27   #65 (permalink)
Member: 2146354
Thanks Meter: 21
Im working on using the oca with loca in it. I will share my results
Old 05-05-2015, 09:34   #66 (permalink)
Member: 523004
thank you, I order, then share results
Old 05-05-2015, 14:06   #67 (permalink)
Member: 15149
Thanks Meter: 61
Originally Posted by cellularman89 View Post
Hi,
so if we put something thin underneath the lcd while laminating the glass to the lcd it will lower the chances of bubbles coming back
like this picture
and not like this picture right
im using the mould aluminium and also under the lcd is aluminium so it will be more sure that when it press is not coming back bubbles
few things that makes problem for lcd:
1. When u laminating oca on the screen or glass be sure no big bubbles other wise for sure you will not success your job (the perfect way is to laminate with without any bubbles if i have bubble somethimes before laminating glass i put oca with lcd to bubble remover for 40 celcius and not more than 10 min if not deseaper air means u have to repeat procedure )
2. when u laminating and u can see a lot of air inside lcd means lcd is not enough up so when machine pressing cannot take out and catch oca with glass and lcd
3. be sure all area lcd is not any old loca or glue or dust this making oca lift up and coming bubbles
4. if bubbles comes around the the screen it could means the oca is unglued around and because stay long time on air is not so good as it was before.
5. keep all oca in the refrygyrator.
6. if you are getting problem i suggest to try oca from bigger model laminate it in the middle then cut around lcd the rest of the oca with sharp knife and then laminate.
i forgot very important do not remove bubbles few times same day even some lcd that have small bubbles they need 1-2 days break before u make another becuase after bubbles will diseapear and comes more i never use more than 40 degreese and 50 is for me too much is better remove air weith lower celcius and longer time but max 15 min if not disepear u need to wait 1-2 days and try again until oca will catch if not u need to cut and make it again dont spent time for nothing
Old 05-08-2015, 23:43   #68 (permalink)
Member: 2391091
Hi guys thats a nice convo
I have the KO NO 1 and sometimes I have to use the Bubble Remover if the KO does not remove all bubbles. I am reburbishing 100-200 LCDs per month.
The only disadvantage of OCA infront of LOCA is, that the dust is more visible. Does anyone has an idea how to work dust free? I built an Laminar Flow Box by myself but sometimes I have dust in 2-3 LCDs out of 10.
Cellularman how is the KN6.2? Maybe I will test this too if the dust isnt that visible.
Old 05-10-2015, 09:06   #69 (permalink)
Member: 2204208
Thanks Meter: 2
waqas1988 whicw machine do you have can you send me a link? i whant to see if we have the same maby i will need your help
Old 05-11-2015, 22:27   #70 (permalink)
Member: 2391091
I am using the Oca Laminating Machine KO 01 but sometimes it does not remove all bubbles. Then you will need the Autoclave.
Old 05-12-2015, 03:47   #71 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
How you getting on with it?
Old 05-13-2015, 23:18   #72 (permalink)
Member: 2146354
Thanks Meter: 21
Here is my attempt with the oca with loca in it
http://www.youtube.com/watch?v=_xK_8ZpLolM
Old 05-14-2015, 21:15   #73 (permalink)
Member: 2384272
When i posted i was using a oca that i donīt even know itīs brand. Now iīm using mitsubish. Since i started using mitsubish, i am having the same problem you had. No bubbles right after autoclave. 1 or 2 bubble come back couple hours later.
I am laminating manually. Like this video on youtube (i canīt post links): How do Chinese laminate the OCA adhesive on the glass of your cell phone
then put the glass (manually) on the lcd and then autoclave. The only machine i use is autoclave
About the autoclave. You said you use 4 or 5 mpa pressure. Itīs a lot of pressure. I am using 60 or 70 PSI, thats equal to 0,4 or 0,5 mpa. To avoid miss understanding, can you send a picture of you manometer when the autoclave is on the right pressure?
Old 05-14-2015, 22:24   #74 (permalink)
Member: 2146354
Thanks Meter: 21
Here is my settings. It ranges from 4-5 mpa. I play with it to see what gets best results
The Following User Says Thank You to cellularman89 For This Useful Post:
Old 05-15-2015, 03:38   #75 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Thanks Meter: 382
I'm very new to all this and still practicing but from my experience if I put in to bobble remover for more then 20 degrees I always have bobbles back in 20 minutes or so. Try to set it to 20 degrees for 20 minutes and hope you newer will have them back.
Hope its helps for you.
Page generated in 0.28628 seconds with 9 queries
