LCD Refurbish All things related to LCD / Screen refurbish and repair |
06-16-2015, 17:26 | #109 (permalink) | |||
Freak Poster Join Date: Apr 2011
Member: 1559845 Status: Offline Thanks Meter: 15 | Quote:
Quote: Quote:
(I'm using Mitsubishi OCA) (Tried different types of adhesive removers does not really matters) When I started working with OCA I used the autoclave a LOT since my laminating skills were bad and sometimes I had bubbles a few days after repairs like 1 out of 10 screens but don't get me wrong the laminating process was not the problem BUT since I was not laminating perfectly, that made the process inside the autoclave longer so the OCA was exposed to vacuum and heat for a longer period of time. So I noticed when I finished the process in under 15 min Laminating 2-4 min Autoclave 6-10 min The chances of bubble would be around 5% When laminating went bad and I had to use autoclave for more than 25min the chances of bubbles a few days after repair would be around 40% So I figured what happens inside the autoclave causes the bubbles and I tried different things like adjusting the values for pressure and heat (I'm not an expert) Did not really make any difference so finally my wife suggested that I put the OCA in the Fridge Before and After every repair and believe it or not guys this has solved my issue 100% the Before part is not that important since most of you take care of your OCA by having them on the fridge at all times probably It's the after that really hits the spot since the OCA get's out of the autoclave at around 40 degrees which is my current setting and it's weak at this point, easier to yield but the cold takes care of that really fast, I leave every screen like 10min- 1 hr after each repair and it's been enough so far, at the beginning I left them like overnight lol So guys I hope this helps some of you having this issue If you have any questions fell free to ask I myself have some questions about iPhone 6 repairs | |||
The Following User Says Thank You to LastDeuS For This Useful Post: |
06-25-2015, 09:02 | #112 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Italy Age: 42
Member: 164613 Status: Offline Thanks Meter: 11 | Hi guys, it seems I solved the bubbles problem. It depends only by the application of the film and how you put them tohether. Last 10 days I made a lot of them, it gets perfect after the first press and I don't use the autoclave!!! The big secret is to have the right plastic molds, I reworked all of them that the distance between the glass+OCA and the LCD must be like 2mm. So when you put the glass it doesn't touch the LCD. you must press with the finger in the middle, then pull out the kit holding only by the sides, put it in the press and that's it! Also I found the method for the iPhone 6 and 6 plus, already made around 15 screens, all perfect!!! For a perfect quality you must pull out the backlight, cut the broken glass, cut out the polarizer, clean it well, apply the new polarizer film, put the OCA on the glass, put them together as I told with the touch in the middle, put under press, when finished install the plastic frame with preapplicated thermal glue (not adhesive film!!!), put it on the hot plate 80C for a couple of minutes, then install NEW backlight and that's it! |
06-26-2015, 19:39 | #113 (permalink) | |
Junior Member Join Date: Jun 2007
Member: 523004 Status: Offline Thanks Meter: 0 | Quote:
07-07-2015, 08:52 | #116 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2423658 Status: Offline Thanks Meter: 2 | Look like im not the only one. Done more than 50 x ip4 screens. Tiny bubbles start to appears on top of the screen "vertically - just below the static bar" after a few days. I have done the following: 1. Applied OCA on lcd panels 2. Put them into autoclave 3. Insert lcd panel into mould 4. Put on front glass lense 5. Press lcd screen with vacuum LCD laminator for 4mins per screen 6. Put them into autoclave 7. Dump screens into freezer for 20mins I think it has to do with the process from begining to the end. Hopefully somone can come up a real solution. I will proceed testing other diff methods, will keep you guys updated. Regards PPD |
07-07-2015, 09:11 | #117 (permalink) |
Member: 2423658 Status: Offline Thanks Meter: 2 | One thing I found most vacuum lcd laminator press are poorly manufactured in China. Most have either 1 large air cylinder press or two mini air cyinder press. Ech time you laminate 2 or more screens per press/cycle, the front glass lense wont be laminated perfectly flat to the lcd panel due to the design. If you take time look at the heating plate press in your vacuum lcd laminator, the moment you shift weight (by just using your hand to move it) to one end other side will lift up by a fraction of few mm. I have both the 1 large air cylinder press or two mini air cyinder press vacuum laminators. I'm using the twin cyclinder designs, to compensate this uneven poor design, you will require 4 air cylinders per coners so look like i need to modify mine laminator machine by adding 2 extra cyclinders on each side and re route the tubings and add on new connectors. Regards PPD |
The Following User Says Thank You to AusWidePPD For This Useful Post: |
07-15-2015, 10:07 | #118 (permalink) |
Insane Poster Join Date: Jan 2011 Location: Romania Age: 34
Member: 1499154 Status: Offline Thanks Meter: 0 | Hi, fellow repair guy's i also want to buy a OCA machine but i dont know witch. Can you help me with a decision? i dont have to much of a budget, also i dont do many LCDs. Is this machine any good? Free ship! Newest with bubble remove machine for 7 inch screens LY898 automatic OCA laminator lcd vacuum laminating machine-in Other Machinery from Industry & Business on Aliexpress.com | Alibaba Group Or this one? https://www.will-hi.com/mt-5-in-1-lc...autoclave.html |
