LCD Refurbish All things related to LCD / Screen refurbish and repair |
12-06-2017, 18:52 | #226 (permalink) | |
Insane Poster Join Date: Apr 2009 Location: Delhi Age: 41
Member: 1006358 Status: Offline Sonork: 100.1583633 Thanks Meter: 74 | Quote:
1) damage due to mishandling 2) size to big or to small 3) stores long time ( oca can use upto 6 month from manufacturing ) if store at 5c to 12c , at 25c can store upto 72 hours only | |
12-06-2017, 19:07 | #227 (permalink) | |
The Following User Says Thank You to onlinebaba For This Useful Post: |
12-14-2017, 19:41 | #228 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2789166 Status: Offline Thanks Meter: 0 | The problem you are having has many causes: 1. When you insert the LCD into the pressure cooker, please set the high temperature (to equal the room temperature). This is the most important 2. When you cover the OCA on the LCD, the edges around the LCD are redundant. 3. When rolling OCA on an uneven LCD may also be the cause. 4, Finally, after trying all the steps above, you change the other OCA provider, or you preserve the OCA glue incorrectly (must be stored in the refrigerator during storage. ) Here are the steps to overcome the phenomenon of bubbles returned after a short time, I have experienced this problem as you, really very difficult to go. Nice to be acquainted with colleagues. |
12-17-2017, 12:22 | #229 (permalink) |
Member: 1006358 Status: Offline Sonork: 100.1583633 Thanks Meter: 74 | Dear Carefully Watch Video, If Still Same Problem so Kindly tell us. Last edited by onlinebaba; 12-17-2017 at 12:28. Reason: Type error |
The Following 4 Users Say Thank You to onlinebaba For This Useful Post: |
03-25-2018, 18:37 | #230 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | where can i buy tha lcd test machine which oca machine is the best..ak pro..m triangle 102 or baku bk-958,,bk 957 olz suggest iam planing to buy. regards! |
06-12-2018, 12:36 | #232 (permalink) |
Junior Member Join Date: Jun 2018
Member: 2843737 Status: Offline Thanks Meter: 1 | bubble problem because you apply too much pressure on the oca when you laminating on the glass, under your hand pressure it contracts and when you put in the autoclave it appears back because of the high temperature. I suggest use less pressure and put glass in autoclave for 10 min / 55'C. |
The Following User Says Thank You to Jhnywalter For This Useful Post: |
06-14-2018, 09:49 | #233 (permalink) |
Member: 2843737 Status: Offline Thanks Meter: 1 | Edit to my post above: I have bigger machine the manufacturing one with its own clean room with specific metalic molds with four layers that machine does glass laminating and then glass on lcd laminating in vacuum but takes some time and whole manufacturing stops until I finish the glass but never use bubble remover, so I got myself a clean room and put the smaller oca laminator like one in your video it has build in vacuum pump, after using it I noticed that problem , thankfully was able to solve that problem by applying less pressure and using bubble remover on glass without lcd. |
01-28-2019, 19:59 | #235 (permalink) |
Junior Member Join Date: Jan 2019
Member: 2890688 Status: Offline Thanks Meter: 0 | Hi friends, I have a problem with Samsung amoled screen repair. When I fix the Huawei LCD, everything is fine. The same oca glue, the same pressure and temperature. In the laminating press: temperature 40 " lamination time 15s. In the bubble remover autoclave - temperature 23", 15 minutes, 6bar.. Huawei is perfect, but Samsung has bubbles. When someone will help me and solve the problem, I offer a gift of 50 $ on paypal Please, let me know about PM. |
01-30-2019, 03:00 | #236 (permalink) | |
Junior Member Join Date: Mar 2018 Location: Ukraine, Nikolaev Age: 49
Member: 2824246 Status: Offline Thanks Meter: 1 | Quote:
In autoclave set temperature to 35, time 7-10 minutes | |
03-05-2019, 07:22 | #240 (permalink) | |
Freak Poster Join Date: Sep 2005 Location: Cebu Phils.
Member: 183390 Status: Offline Thanks Meter: 74 | Quote:
