cellularman89 | 04-27-2015 23:04 | Quote:
Originally Posted by maxevita
(Post 11012674)
one other issue with the machine ko, then uses remove bubbles, perfect after I there are always problems of bubbles that everyone is talking about?
Also, because I have to buy, and I would not spend $ 2,000, then to have problems after bubbles
please help to buy a machine that has no problems, some advice from some model that you have? | KO machine works very well. It had a air compressor already built in and does not make alot of noise.
The only reason I would say buy another machine is only if you do bulk refurbishing. like hundreds in one day. If you do on a small level this ko is just fine.
The bubble problem is not because of the machine but is because of not properly using the machine. So if you do decide to buy the ko you have to get the hang of it to not get bubbles, same as any other machine |
