Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 08-09-2016, 07:09   #196 (permalink)
Member: 257372
Hi all !
This is my experience :
- Apply OCA sheet on LCD of polarized area .
- Do not press on screen after laminate .
- Temperature of bubble remove machine depent of time , ex : 65 degree in 5 minus , pressure 4kg/cm2
I don have bubble any more .
Old 08-09-2016, 21:16   #197 (permalink)
Member: 1714728
Thanks Meter: 7
Originally Posted by screatives View Post
Because if the polarizer have some scratch the bubble come
Inviato dal mio iPhone utilizzando Tapatalk
i think you are using uv sheets instead use uv glue so that you can not face this bubbles problems
Old 10-05-2016, 15:45   #198 (permalink)
Member: 1925555
Thanks Meter: 6
Originally Posted by bajinchi View Post
Hi,
Iīm having an issue refurbishing iPhone 6 & 6+ screens, if I change the polarized film, the touchscreen *****, or donīt work, or works with flaws.
Iīm also putting the conductive paste in the upper corners... but no idea why this happen.
If I donīt change the polarized film, no problems at all, all working excellent, so itīs not the glass ond OCA.
If you have an advice, would be great.
Thanks
iPhone 6 & 6 plus display & touch panel is very thin; flex cable on top is longer and just a little connecting with panel on both side, in middle is empty so flex cable on both side is very easy get off the panel. I got problem with touch motion not responsive after remove polarizer because my cutter was hit this area. If you pay more attention and not pull too much liquid cleaning on top area when remove polarizer then you can address this issue.
Old 10-11-2016, 01:27   #199 (permalink)
Member: 1925555
Thanks Meter: 6
Originally Posted by jackvonthor View Post
Hello guys
Have you tried replacing the glass in iPhone 6s Plus?
I got some problems , here is the effect:
I am using laminator GM968 , temp. 35 degrees for 5 minutes.
Next I use autoclave (model GM838) for 9 minutes, 40 degrees..
Do you guys also got problems with iphone 6S Plus?
I'm not really sure about your baby model (your marchin) but your photo look like it does not have enough pressure or no threshold pass time setting. What is level of pressure and vacuum ?
Old 10-13-2016, 10:10   #200 (permalink)
Member: 1714728
Thanks Meter: 7
sir i am planing to purchase this machine is it useful or not please suggest me if use full please tell me the best model to purchase cost thank you
Old 10-13-2016, 22:03   #201 (permalink)
Member: 1925555
Thanks Meter: 6
My babe was bought 2014 - a TBK 5 in 1 - after few weeks I got trouble, my friend can speaks Chinese and helped me contact with manufacture for detail but never got a right answer then end up I had to open it up and modified everything by my own, changed conpressure, vacuum pump, replace all air line with US measurement then it works as my respected until now.
Trust my, the Chinese has a good design but merchandise never has a good quality. After 2 years there are a lot of new model out there and cost more than thousand dollars. If I need another marchine, I will not buy a new one and not combo all in one any more.... I suggest if you are handy just buy a old model and single stage. You just need 2 marchines : wax-bonding (laminate) and bubbling removal, those I think will less than a thousand - then buy a compressure and vacuum pump about $300 max then you will have your quality marchine fix as you need.
When you have separate compresure/vacuum it can help you do more things then a build in. I don't have clean room (build a clean room for refurb LCD is a crazy idea because it cost more than 30,000 dollars in US), I just designed my own box call glove box to free particle (count smaller than dust) when I install glass on LCD panel inside my glove box, the vacuum is not only for bubbling removal, it also is helping my glove box with particle free.
My 21 gallon compresure also do more job then bonding glass on LCD, it use for cleanning, automotive repairing and house painting...
If you are going to do business with this LCD refurb, just build your own with single stage of marchine, not by 3 or 5 or all in 1 not save you money and made more trouble for you after few weeks.
The Following 3 Users Say Thank You to emvp For This Useful Post:
Old 12-16-2016, 13:43   #202 (permalink)
Member: 2661594
Pressing on the glass was probably the main reason for the bubble return! If it comes back to haunt you later down the road try throwing it back in the heat plate for 5-min (this will make the bubbles even bigger don't let that concern you.) then put straight into the auto clave for another 20min and the bubbles should be gone for good
Old 12-19-2016, 13:48   #203 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 756
i m using
mitshubishi oca
professional laminator machine took only 26 second
big bubble remover 45c and 15 minuts
even on 6s+ all is well
Old 12-19-2016, 13:53   #204 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 756
must buy professional machine and separate for laminat and bubble remover
The Following 2 Users Say Thank You to chand_gee For This Useful Post:
Old 12-19-2016, 16:52   #205 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 756
wrong
i make full videos off my machine pm for links...........
The Following User Says Thank You to chand_gee For This Useful Post:
Old 12-28-2016, 21:31   #206 (permalink)
Member: 2654250
Please send me link to my inbox
Old 12-29-2016, 14:11   #207 (permalink)
ps
Member: 327
Thanks Meter: 5
Please send me link
Old 01-12-2017, 23:48   #208 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 756
https://www.youtube.com/channel/UC6N...mLIM7C0Od5KbCg
check here videos
Old 01-13-2017, 13:41   #209 (permalink)
Member: 1738539
Thanks Meter: 11
I worked in one of the biggest display/touch factories in China. And right now ,I run Universal Display.
And it is normal that the bubble existed on certain percentage of the display or touch after the adhesive process . In the factory,we use one special machine the drive the bubble out.
If anyone need, I might be able to convince some factory to do the process professionly for you. Please note it.
The Following User Says Thank You to daneremail For This Useful Post:
Old 01-23-2017, 07:47   #210 (permalink)
Member: 2135622
oca bubles comes after some time
bubles comes after some time due to machine because there are machine in market which efficiency is not good to do lcd limination with accuracy. so i suggest to all foram memeber to purchase machine from certified factory. so post your problem with your machine picture that which machine was using
Page generated in 0.39983 seconds with 7 queries
