Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 01-23-2017, 08:41   #211 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
Originally Posted by faizi_khalid1 View Post
bubles comes after some time due to machine because there are machine in market which efficiency is not good to do lcd limination with accuracy. so i suggest to all foram memeber to purchase machine from certified factory. so post your problem with your machine picture that which machine was using
NOT agree. My machine is almost 3 years old.
Certified Factory ... from who? Samsung? Apple? HTC?
noone of them will sell such machines, all is cheep working copies.
need practice and good adhesives, thats all.
Old 01-23-2017, 11:17   #212 (permalink)
Member: 2135622
but brother its fact in 4 in one machine am working with these from last 7 years am selling branded machine. when machine quality is good no need too much practice and no need good adhesive
Old 01-23-2017, 12:28   #213 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
Now i agree all 3in1 4in1 .... are full BS.
all those types machines is compromise of quality for the price.
Old 01-27-2017, 19:52   #214 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 752
i m not agreee with you.....
Old 03-08-2017, 14:12   #215 (permalink)
Member: 45771
Sonork: 1580823
Thanks Meter: 14
i have many problems with bubbles and first problem very clean glass !!! when you clean with the best clean liquid evrithing while be ok !!!
second problem is temperature work place ....
The Following User Says Thank You to mobiservice For This Useful Post:
Old 03-08-2017, 16:33   #216 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 41
what you mean?
my workplace is 25 degrees at worktime, at night drop below 5 degrees.
Old 07-17-2017, 18:52   #217 (permalink)
Member: 1380495
anyone have new models machine
Sent from my iPhone using Tapatalk
Old 07-22-2017, 02:04   #218 (permalink)
Member: 2739239
Hello guys.
I have no problem with bubbles in the middle of the screen but in the corners, most of my screens are coming out of the autoclave with 1 to 3 small bubbles in any corner of the LCD.
Here is the configuration of my machine:
Vacum Time: 15s
Lamination: 45s
Debubbling: 20 mins
Outgassing: 5
Temperature: 40C
Pressure: 7 MPA
Tomorrow I will change the lamination time, temperature and time of the LCD in the autoclave, return with the result.
Originally Posted by gucesar1 View Post
Excuse my English, I am using a translator.
I'm from Brazil and now started a company to refurbish the display`s.
Like all had problems with the machine bubbles and the only solution was testing behind test.
And get to 100%.
The tip I can tell you is the setting machine pressure. They come with regulated pressure sea level of China. So you have to adjust the pressure and temperature. So to get to 100% perfection.
My I regulated the machine to sea level in my town, I moved 10 minutes to 15 minutes time and raised the temperature to 35 degrees.
Use hollow Mitsubishi, and I do not have any problem with bubbles.
I hope to help with these tips.
Can I contact you in private? I am also from Brazil, more specifically from Santa Catarina, I would like just a few tips regarding the problem that I am facing, I promise not to bother for long.
Thank you!
Old 07-23-2017, 02:45   #219 (permalink)
Member: 2739239
Originally Posted by Daqu View Post
Hello guys.
Vacum Time: 15s
Lamination: 45s
Debubbling: 20 mins
Outgassing: 5
Temperature: 40C
Pressure: 7 MPA
I followed some tips from gucesar1 and I programmed my machine to:
Vacum Time: 15s
Lamination: 120s
Debubbling: 10 mins
Outgassing: 5
Temperature: 50C
Pressure: 7 MPA
It worked perfectly, the problem of bubbles in the corners disappeared.
Old 07-23-2017, 06:38   #220 (permalink)
Member: 525940
Thanks Meter: 201
can anyone post picture and good quality or tested polarized film and oca you are using?
Old 08-02-2017, 05:37   #221 (permalink)
Member: 2125605
Thanks Meter: 5
The problem for the bubbles is the oca theirs a lot people claiming to sell original oca from Mitsubishi but it's false advertising / if you have original Mitsubishi oca and you have a bubble you don't even need laminating machine in couple of hours it will removed by itself .
The Following User Says Thank You to alexz408 For This Useful Post:
Old 09-24-2017, 17:54   #222 (permalink)
Member: 2429802
I am looking to work with OCA, I am researching on the equipment but my doubt is about the autoclave. Can it be from medical laboratories? Because in my country, the ones for OCA are very expensive, and the laboratories are already used for a great price.
Old 09-25-2017, 04:21   #223 (permalink)
Member: 1348482
remove glass no need machine https://www.youtube.com/watch?v=3dhur4X7GCw
Old 12-06-2017, 17:47   #224 (permalink)
Member: 1006358
Sonork: 100.1583633
Thanks Meter: 72
Dear Follow below step for prevent bubble
1) after put oca on glass or Tp put in bubble remover for 5 miniutes at temp 45c, pressure 0.4mpa
2) after positioning of Touch Panel on lcd , very little press from center
3) for vacuum pressing set parameter as below
vacuum time 6 to 8 seconds
hold time and pressure : t 5 seconds pressure 0.4 map
temp 55c
bubble remover : temp 40c, time 15 miniutes, pressure 0.35mpa
all parameter will change with oca material or glass ink thickness
Thanks and Reg
Polar Electronic Pvt Ltd
Old 12-06-2017, 17:49   #225 (permalink)
Member: 1006358
Sonork: 100.1583633
Thanks Meter: 72
yes bro it's same, only setting as I mention above
Page generated in 0.34816 seconds with 7 queries
