Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 04-27-2015, 22:43   #46 (permalink)
Member: 2146354
Thanks Meter: 19
Wd40 on a paper towel
Originally Posted by benistinc View Post
i have some prablom when i remove the polroizer in the iphone 5 when i remove the glue some of the adhesive remover get in the backlight how you do it
I can make a video showing how to do it with wd40 and a paper towel. It takes alot of time and patients though. Tell me with you want me to make. I dont mind at all
Old 04-27-2015, 23:00   #47 (permalink)
Member: 2146354
Thanks Meter: 19
DO you mean put something under lcd in laminator
Originally Posted by ZetMen View Post
guys i had some of problems like you with oca and i solved, problem usualy when u installing oca on the lcd or when u laminate the screen is down becuase the part of the tape from back of the lcd left in the frame then u need to put something under lcd inside mould to laminate good its shouldnt be almost nothing bubbles if anyone have more questions please contact me on skype
Hi,
so if we put something thin underneath the lcd while laminating the glass to the lcd it will lower the chances of bubbles coming back
like this picture
and not like this picture right
Old 04-27-2015, 23:04   #48 (permalink)
Member: 2146354
Thanks Meter: 19
Originally Posted by maxevita View Post
one other issue with the machine ko, then uses remove bubbles, perfect after I there are always problems of bubbles that everyone is talking about?
Also, because I have to buy, and I would not spend $ 2,000, then to have problems after bubbles
please help to buy a machine that has no problems, some advice from some model that you have?
KO machine works very well. It had a air compressor already built in and does not make alot of noise.
The only reason I would say buy another machine is only if you do bulk refurbishing. like hundreds in one day. If you do on a small level this ko is just fine.
The bubble problem is not because of the machine but is because of not properly using the machine. So if you do decide to buy the ko you have to get the hang of it to not get bubbles, same as any other machine
Old 04-27-2015, 23:08   #49 (permalink)
Member: 2204208
Thanks Meter: 2
celluarman can you do the video and do you have skape?
Old 04-28-2015, 00:19   #50 (permalink)
Member: 2146354
Thanks Meter: 19
skype
skype name: cellularman89
Old 04-28-2015, 01:16   #51 (permalink)
Member: 498132
Thanks Meter: 15
MAKE SURE YOU CHECK EXPIRATION DATE OF OCA GLUE IF ITS NEARING TO DATE YHE ITS NOT Good FOR REPAIR
Old 04-28-2015, 01:22   #52 (permalink)
Member: 1730357
look for a better loca adhesive using ultraviolet light to dry the glu.
Old 04-28-2015, 01:53   #53 (permalink)
Member: 2146354
Thanks Meter: 19
Hi. How do you check expiration on the oca tape? I see no expiration on the front label.
Also I keep my oca in the freezer so it can stay fresh
Old 04-28-2015, 01:54   #54 (permalink)
Member: 2146354
Thanks Meter: 19
Are you speaking of oca that has loca in it?
Or
Loca Alone?
Old 04-28-2015, 10:00   #55 (permalink)
Member: 2204208
Thanks Meter: 2
cellularman you on the skape?
Old 04-28-2015, 13:08   #56 (permalink)
Member: 188423
Hello Everybody .Bought oca vacuum lamination machine last week,but dont know how to use it.I mean ,what about presure ( 2-3 bar.) and lamination time ( 1-3 min.)?Thanks
Old 04-28-2015, 13:16   #57 (permalink)
Member: 2204208
Thanks Meter: 2
pioery whice machine you buy?
Old 04-28-2015, 19:01   #58 (permalink)
Member: 523004
thank you very much and I wanted to know, if always very polite
Old 05-01-2015, 09:14   #59 (permalink)
Member: 523004
someone came the film oca, for drying UV rays?
Old 05-01-2015, 09:15   #60 (permalink)
Member: 523004
you can tell where you buy it?
Page generated in 0.39109 seconds with 7 queries
