LCD Refurbish All things related to LCD / Screen refurbish and repair |
07-16-2017, 22:47 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2675546 Status: Offline Thanks Meter: 2 | Chemicals used on lcd refurbrish we use few liquids to ref iphones and samsung lcd. now we use to remove glue under polarizer film from china supplier, works perfect. Name is LCM cleaner, just need to few peels of it, works perfectly with brush for painting, no need use blade to remoove glue at all, but delivery from china is very expensive. we are from Europe and anyone used some european sources thise kind of liquid. also soon share some liquids we use more |
The Following 2 Users Say Thank You to x1.lv For This Useful Post: |
07-17-2017, 03:20 | #3 (permalink) |
Insane Poster Join Date: Sep 2011
Member: 1662358 Status: Offline Thanks Meter: 32 | There's a spray called "contact cleaner", used mainly for cleaning connectors on boards, which is fairly inexpensive but highly effective. I use it to remove any glue residue off the LCD's then use an LCD cleaner for shine. Until now I've never had any problems! Remove Glue Liquid oca |
The Following User Says Thank You to myrwok For This Useful Post: |
07-17-2017, 03:48 | #4 (permalink) |
Member: 1662358 Status: Offline Thanks Meter: 32 | spray called "contact cleaner" Olive Oil 2 - Aceite de oliva MOTOR OIL Wd-40 8022 POL remover WD-40 Specialist Electrical Contact Cleaner Spray Acetone 91% Isopropyl Alcohol, Mass Airflow Sensor Cleaner Electrical Contact Cleaner |
