Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 11-15-2018, 06:55   #16 (permalink)
Member: 2748073
Thanks Meter: 7
What kind of wire should I use with iphone screens?
Old 12-14-2018, 18:44   #17 (permalink)
Member: 1004807
Good job sirrrrrrrrrrr tanks
Old 12-18-2018, 08:16   #18 (permalink)
Member: 2876475
use TMF for LCD REFUBRISH
Old 12-23-2018, 18:59   #19 (permalink)
Member: 2729682
Thanks Meter: 5
What is TMF wire, never heard of it
Old 12-24-2018, 10:50   #20 (permalink)
Member: 2729682
Thanks Meter: 5
You can buy an lcd and digitizer for iphone 6s on ebay and its not expensive, comes with instructions for fitting.
Old 01-02-2019, 22:26   #21 (permalink)
Member: 2669985
Its good job but with a very bad LCD alignment and if not use cold glue to align frame on it, its not worth the hard work. Better use 3in1 or 4in1 cold pressed frames for iPhone LCDs to have a better result
We use 0,05mm Gol Wire from Shark in most cases! Its Molybdenum wire and is available in different thickness depending on OCA to cut.
spiral27
You can do a lot of things if u wanna but if you love your device or want ur customer to come back, you should buy refurbished original LCDs or refurb them by ur own. Aftermarket screens are crap. Up from 6S theres no option for good results in color depth, brightness and precise fitting in device. I would never recommend to buy copy screen for iPhones. The Backlights are bad, often issues with homebutton and at least up from Ip8 troubles with Ambient Light Sensor and True Tone function.
You will allways have to be scare if an IOS Update is released.
Page generated in 0.19159 seconds with 7 queries
