Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 03-01-2013, 21:52   #1 (permalink)
Member: 1892481
Thanks Meter: 4
iphone 5 Glass separation
hey guys new here been tied on seeing all the things online about how hard it to remove the glass on the iphone 5 we have been doing it for months and now going to start doing for others will save money on the £160 display at the moment when we can make them look brand new again for £40
Proof on lcd out of glass the glue is harder to remove than the glass can be seen in picture
The Following User Says Thank You to iRepairUK For This Useful Post:
Old 03-02-2013, 00:43   #2 (permalink)
Member: 1481974
Thanks Meter: 42
whats the process you go about doing it?
The Following User Says Thank You to alfyguy For This Useful Post:
Old 03-02-2013, 23:27   #3 (permalink)
Member: 1892481
Thanks Meter: 4
we are keeping that to ourselfs at the momenet we do use
Molybdenum String though
http://www.youtube.com/watch?v=EzLXXfPYezU
Old 03-02-2013, 23:37   #4 (permalink)
Member: 1892826
Thanks Meter: 10
it look like i5 clone's
The Following User Says Thank You to SmokeSignals For This Useful Post:
Old 03-03-2013, 11:40   #5 (permalink)
Member: 1892481
Thanks Meter: 4
how on earth do u think its a clone?
Old 03-03-2013, 12:22   #6 (permalink)
Member: 1892481
Thanks Meter: 4
better video
iPhone 5 screen Seperated and cleaned shown working iPhone 5 repair for less - YouTube
Old 03-03-2013, 12:36   #7 (permalink)
nae
Registered User
Member: 215866
Sonork: 100.1617874
Thanks Meter: 125
it is not a secret
Glass screen only replacement for the galaxy s2, s3, iphone 4, 4s, 5, - YouTube
I personally do this on a htc 8x by removing in small pieces , one by one the old digitizer and took me a long time to finish the job
The Following User Says Thank You to nae For This Useful Post:
Old 03-03-2013, 16:40   #8 (permalink)
Member: 1892481
Thanks Meter: 4
Originally Posted by nae View Post
it is not a secret
takes us about 4 minutes to remove any glass most of that is on our heat pad
Old 03-03-2013, 17:22   #9 (permalink)
Member: 1892826
Thanks Meter: 10
how much coast replacement glass?
Old 03-04-2013, 12:13   #10 (permalink)
Member: 1892481
Thanks Meter: 4
the glass wholesale is £9
Old 03-05-2013, 08:56   #11 (permalink)
Member: 681965
Thanks Meter: 4
what are those heating pads called? I don't know what to search for... searching heating pads brings up dog beds.. I wanna try this..
How hard is it cleaning the glue off the LCD? And how hard is it when assembling to not get dust and air bubbles in between?
Lastly is it as strong as original? i.e; can you separate again easily??
Great solution for iPhone 5 screens!!
Old 03-05-2013, 09:00   #12 (permalink)
Member: 681965
Thanks Meter: 4
and I don't understand this video then.. If you have removed the glass how do you still have touch sensitivity? Is there another layer of the digitiser that doesn't come off when removing the glass?
Correct me if I'm wrong are you separating the glass lens from the digitiser and LCD? So once separated your LCD has two connectors attached right?
Old 03-05-2013, 10:45   #13 (permalink)
Member: 1892481
Thanks Meter: 4
the screen in the iphone 5 have the lcd and digitizer as one the touch still works fine when the glass it taken off its the optical adhesive they use that is hard to remove from the lcd take long that removing the glass
Old 03-05-2013, 10:47   #14 (permalink)
Member: 1892481
Thanks Meter: 4
the heating pad we use is part of are rework station we picked up in china the lcd is fine but i will say the optical adhesive we use to bond the screen back to the lcd is stronger and we have not had to try and remove yet as for dust makre sure a clean room used and for air bubble we use a vacum pump afterwards to clear them out
Old 03-05-2013, 13:26   #15 (permalink)
Member: 1892826
Thanks Meter: 10
great work sir & thank's for sharing
so can we do the same for ipad4?
and when can i get replacement glass for it?
Page generated in 0.21333 seconds with 8 queries
