Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 03-12-2017, 22:21   #1 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
LCD Separating/Cutting Gold Wire
If you are going to replace broken glass of any LCD.
You need this wire for separate broken glass.
there are many wires available in market.
different length size and different diameter.
During separate glass mostly you will get scratches
on Polarizer then you need to replace its risky and costly.
----here i show you how to avoid damage polarizer---
always use thin wire to avoid damage polarizer
recomended diameter of cutting wire is .06 mm
there is also 0.04 mm butt i did not try yet.
1-
2-
3-
4-
5-
6-
The Following 21 Users Say Thank You to chand_gee For This Useful Post:
Old 06-20-2017, 08:14   #2 (permalink)
Member: 937338
Sonork: 100.1651155
Thanks Meter: 114
sir please sugest best touch replacment machine for replace glass of a5 j7 mobile thank you
Old 06-20-2017, 09:45   #3 (permalink)
Member: 125037
Sonork: 100.1649338
Thanks Meter: 254
there are many different models and mnufacturers
As long as itīs not a fake copy go for any.
X4ce
The Following User Says Thank You to excessive For This Useful Post:
Old 07-30-2017, 00:09   #4 (permalink)
Ahmadaim1's Avatar
Member: 2165294
Thanks Meter: 59
Recommended temperature for most especially Chinese smart phones pls
Sent from my Infinix HOT 4 using Tapatalk
The Following 2 Users Say Thank You to Ahmadaim1 For This Useful Post:
Old 08-08-2017, 02:01   #5 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
80 cc for iphone becarefull high temperature will damage backlights of iphone lcd...
100 cc for Samsung can easily separate..
In chines phone if ips display then 80cc
If amoled like Samsung then 100cc.
I hope the answer of your question..
The Following 17 Users Say Thank You to chand_gee For This Useful Post:
Old 08-08-2017, 02:09   #6 (permalink)
Registered User
Member: 1904242
good job sir....thank this big guide for me new here..
Old 08-15-2017, 14:29   #7 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
welcome to you hope you will gett better information here...
The Following 5 Users Say Thank You to chand_gee For This Useful Post:
Old 09-25-2017, 04:23   #8 (permalink)
Member: 1348482
Thanks Meter: 7
no need any wire or machine https://www.youtube.com/watch?v=3dhur4X7GCw
Old 09-26-2017, 12:04   #9 (permalink)
Ahmadaim1's Avatar
Member: 2165294
Thanks Meter: 59
Originally Posted by tu0977717405 View Post
Awesome but it will work on iPhone only bcz its the only phone that doesn't require much heat
Old 10-01-2017, 01:58   #10 (permalink)
Member: 2499481
much tougher iphone for glass exchange
Old 05-06-2018, 22:38   #11 (permalink)
rahul_rocks3's Avatar
Member: 1312746
Thanks Meter: 766
which touch separator is the best for use
Old 05-07-2018, 15:34   #12 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
@All
all pictures links are updated after technical issue in postimg.org
The Following User Says Thank You to chand_gee For This Useful Post:
Old 06-25-2018, 13:47   #13 (permalink)
Member: 917080
Thanks Meter: 13
which of the wire is the best to separate LCD ?
Old 07-04-2018, 15:35   #14 (permalink)
Member: 2837500
Very usefull thankyou somuch sir thanks
Old 10-16-2018, 19:23   #15 (permalink)
Member: 64823
Thanks Meter: 439
Video is DEAD !! Please Refresh @@
Page generated in 0.18805 seconds with 8 queries
