Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 03-07-2018, 08:34   #1 (permalink)
Member: 2621291
Thanks Meter: 124
LG K10 2017 screen glass replacement only / lcd refurbish video guide
To complete the glass only replacement in LG K10 2017 FOLLOW THE STEPS FROM THE GUIDE:
http://www.youtube.com/watch?v=RrKzqKdKmBA
Old 03-27-2018, 09:57   #2 (permalink)
Member: 2630469
Thanks Meter: 8
My screen is cracked and touch does not work. If I replace the screen will it work?
Old 04-01-2018, 13:12   #3 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 253
No, if touch doesn't work then you have to replace whole assembly. Digitizer is part of the display in K10 2017.
Old 05-17-2018, 07:21   #4 (permalink)
Member: 2837953
My touch work but screen is completely shattered, so I can follow the tutorials, yes?
Old 05-17-2018, 18:07   #5 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 253
If by screen you mean just the glass and you're able to see everything just fine on the screen then yes, you can. Keep in mind that you need laminator and autoclave to properly do this with OCA.
Old 05-21-2018, 13:44   #6 (permalink)
Member: 2621291
Thanks Meter: 124
The touch must work properly to perform such a repair.
Old 06-06-2018, 12:20   #7 (permalink)
Member: 2837953
Yes, the touch works properly, I will try to do it along with the tutorial, I hope I will be able to do it, thanks!
Page generated in 0.11786 seconds with 8 queries
