Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 11-17-2017, 18:01   #1 (permalink)
Member: 2382021
replacement glass Samsung S8 G950
Hello
I have a problem taping the back of the display
After striping, the stripes (vertical lines) remain as shown
During disassembly I use isopropanol
Is this a mistake?
Are there molds for the press without taping the tape from the display?
Old 11-20-2017, 09:43   #2 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
Thanks Meter: 129
i have also same problem after removing S7 edge from middle frame...
now touch not responding...
same happened with 2 sets...all care taken while unframe
wbr...
The Following User Says Thank You to ..:MumbaiGsm:.. For This Useful Post:
Old 11-20-2017, 10:28   #3 (permalink)
Member: 2382021
I had a problem with the first piece in the s7 edge. I left for the night with the window open and the chemistry evaporated. The temperature was about 5-7 degrees celcius. He started to touch
what method do you use? Will you put a patch OCA on the display or on the glass?
Old 11-23-2017, 17:08   #4 (permalink)
Member: 2382021
You have to start separating from the plug side
Page generated in 0.11116 seconds with 8 queries
