Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 12-23-2016, 21:28   #1 (permalink)
Member: 2621291
Thanks Meter: 73
Samsung Galaxy S7 G930f screen glass only replacement tutorial
I would like to share with you my latest work with Samsung Galaxy S7. In this video you will find about screen replacement technique I used to achieve such a result. I hope you will find it helpful!
Link to the video - Samsung Galaxy S7 screen replacement
The Following 2 Users Say Thank You to eselekt For This Useful Post:
Old 12-26-2016, 23:48   #2 (permalink)
Member: 2630469
Thanks Meter: 4
How long does it take to make such a repair?
Old 12-30-2016, 08:19   #3 (permalink)
Member: 2621291
Thanks Meter: 73
It can take up to 4 hours.
Old 01-02-2017, 14:31   #4 (permalink)
Member: 2641406
Thanks Meter: 59
I've never done a glass only on a bonded screen. But from handling alot of bare LCD panels before, how do you clean off all the old glass and fingerprints? This has always seemed like an impossible task but your panel is squeaky clean!
Old 01-02-2017, 21:00   #5 (permalink)
Member: 1518920
Thanks Meter: 7
great skills guys! it's really difficult to do this as well as you show
Old 01-05-2017, 11:33   #6 (permalink)
Member: 2621291
Thanks Meter: 73
It's difficult but possible, work hard and practise will come in time
Old 01-22-2017, 22:58   #7 (permalink)
Member: 1518920
Thanks Meter: 7
Could you make video with Samsung S6 glass replacement? BR
Old 01-24-2017, 07:54   #8 (permalink)
Member: 2621291
Thanks Meter: 73
Sure, not problem bro. I will let you know when it happens
The Following User Says Thank You to eselekt For This Useful Post:
Old 02-11-2017, 11:28   #9 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,081
now we hava a dedicated section for lcd refurbish .
Old 08-02-2017, 08:47   #10 (permalink)
Member: 2630469
Thanks Meter: 4
It would be better if you use youtube bracket, it is much faster. As I did here:
http://www.youtube.com/watch?v=ZaFVBeCm-co
Old 08-03-2017, 13:20   #11 (permalink)
Member: 2452969
I wonder if with s7 edge is the same process
Old 09-08-2017, 12:23   #12 (permalink)
Member: 2621291
Thanks Meter: 73
Is pretty much the same but more complicated, you shoul use freezing machine do replace edge glass.
Old 09-12-2017, 23:01   #13 (permalink)
Member: 1031620
hi.I WANT TO BUY MACHINES TO REPLACE GLASS FOR NOTE5 ,S6,AND S7 .I HOPE THAT I DO IT LESS THAN 25 MIN PER EACH IN HUGE AMOUNT .I DONT HAVE ANY IDEA ABOUT MACHINES .I DID S5 OR S4 OR A SERIES BY HAND WITH HOT PLATE AND UV LED .WHAT IS YOUR IDEA IT IS POSSIBLE LESS THAN 30 MIN TO DO IT ?IF YES PLEASE ADVICE ME SOME MACHINES TO BUY IT
Old 09-19-2017, 07:40   #14 (permalink)
Member: 2621291
Thanks Meter: 73
As the beginner you will need to spend much more time than this. Start you business journey with the separator first. Get skills and then you can move further.
Old 09-26-2017, 17:55   #15 (permalink)
Member: 1518920
Thanks Meter: 7
What kind of separator do you recommend?
Page generated in 0.49377 seconds with 7 queries
