Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 06-13-2018, 06:44   #1 (permalink)
Member: 2621291
Thanks Meter: 124
Liquide nitrogen glass separation / glass only replacement for SONY XPERIA models
This tutorial will show you how to replace the glass in Xperia Z2 using nitorgen machine:
http://www.youtube.com/watch?v=LKfwCIoMwOQ
The Following 4 Users Say Thank You to eselekt For This Useful Post:
Old 06-13-2018, 14:54   #2 (permalink)
Member: 92260
Thanks Meter: 843
Interesting... no damage at all to liquid crystal / omoled cells or electronics?
Old 06-18-2018, 06:31   #3 (permalink)
Member: 2621291
Thanks Meter: 124
No damage at all. Everything works as new again.
Old 06-21-2018, 12:51   #4 (permalink)
Member: 2837953
Any additional tools for this machine?
Old 09-03-2018, 13:30   #5 (permalink)
Member: 2621291
Thanks Meter: 124
No need to use additional tools the machine itself do the all work.
Old 09-18-2018, 10:31   #6 (permalink)
Member: 666414
Thanks Meter: 38
Are you working with this machine ?
Can it help to remove complete folder from set with broken touch ?
Old 09-27-2018, 06:41   #7 (permalink)
Member: 2621291
Thanks Meter: 124
Yes, if you get handy with it you can separate anything you like. Take time and learn.
Old 10-01-2018, 14:05   #8 (permalink)
Member: 2837953
I'm beginner which one will be better for me (freezing or heating machine)?
Old 11-15-2018, 07:52   #9 (permalink)
Member: 2748073
Thanks Meter: 8
This machine makes my job much easier, good job you share your experience with us.
Old 02-22-2019, 08:42   #10 (permalink)
Member: 2764058
Will it work with HUAWEI phones properly? I've started to repair a lot of them and I'm planning to invest in such a machine.
Old 03-03-2019, 03:17   #11 (permalink)
Member: 65319
Thanks Meter: 5
Is it possible to use a freeze spray such as MAX Professional 7777 **** Off Freeze Spray Electronic Component Cooler an alternative to liquid nitrogen?
Old 02-12-2020, 12:56   #12 (permalink)
Member: 2634426
Thanks Meter: 15
It will be not efficient, the glass should be frozen at the same temperature at the whole screen
Page generated in 0.23996 seconds with 9 queries
