10-06-2018, 10:56 | #1 (permalink) |
Insane Poster Join Date: Apr 2014 Location: India
Member: 2163730 Status: Offline Thanks Meter: 48 | Need...Help Oppo A3s Cph1803 Pattern Unlock Plz.. Very Dimand For This Model.. Not Support Any Profesinal Boxes So Please Help Any Solution 100% working Solution Needed Thanks Team |
10-16-2018, 15:47 | #5 (permalink) | |
Freak Poster Join Date: May 2004 Location: Dream
Member: 64496 Status: Offline Thanks Meter: 76 | Quote:
Interface: UFI High-Speed Serial number: XXXX-XXXX-XXXX Boot version: 1.04, FW version: 1.11 (Dec 6 2017 17:13:32) Insertion test... Done. Init bus... VCC: 3.0 V, VCCQ: 2.8 V Bus: 1 bit (SDR 16MHz) Access mode: sector mode Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V) Card/BGA: BGA (Discrete embedded) - High density MMC Manufacturer ID: 0x15 (Samsung) Product name: QE63MB (0x514536334d42), rev: 0x06, serial number: 0xFBF7D880 Manufacturing date: Jun 2018 CID: 15010051 4536334D 4206FBF7 D8806588 CSD: D0270132 0F5903FF F6DBFFEF 8E40400C EXT_CSD revision: 1.8 (MMC v5.1) Partition info: Boot1: 4096 KiB Boot2: 4096 KiB RPMB: 4096 KiB User area: 14.56 GiB(15,634,268,160 bytes) Scanning "/data" partition... Done. Remove User Lock... error: failed to mount fs (encrypted block?) ! failed | |
10-16-2018, 16:12 | #6 (permalink) | |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | Quote:
special task factory reset nota gajah | |
