07-01-2016, 20:06 | #1 (permalink) |
Crazy Poster Join Date: Jul 2015 Location: Future Age: 29
Member: 2425358 Status: Offline Thanks Meter: 53 | Oppo F1Plus MT6755 imei repair mt 6755 supported in maui meta 9.1604 but cannot find nvram database files i tried to get it from phone but cant root this device somebody share mt 6755 bplgu modem file please |
09-16-2016, 17:15 | #5 (permalink) |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | |
The Following User Says Thank You to aryanmobile1989 For This Useful Post: |
04-13-2017, 14:09 | #7 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Bangladesh Age: 32
Member: 2364514 Status: Offline Thanks Meter: 390 | bro try 1. Rooted your MTK Android phone 2. Download and install Mobile Uncle Tools from Google play store. 3. Go to Engineer Mode and Select Engineer mode (MTK) 4. Go to Connectivity Tab and Select CDS information 5. Select Radio Information after that Select Phone1 (for the first IMEI) 6. At the top there is a command line which begins “AT+” just type there “AT +EGMR=1,7,”IMEI_1? (Put your first IMEI number number) 7. Hit send command and you will / may get a confirmation that "sent to mSend". 8. Now go back and select “Phone2? (for the second IMEI number) 9. At the top there is a command line which begins “AT+” just type there “AT +EGMR=1,10,”IMEI_2? (Put your second IMEI number) 10. Reboot your phone and check you IMEI number (Dial *#06#). Must Read :- Latest Google play store for any Android device lost-IMEI-Numbers Must Read :- TheftSpy Anti-Theft app for Micromax A110 and other Android mobile Second Method: - 1. Go to Engineering Mode with this code * # * # 3646633 # * # * 2. Type it on call pad 3. Engineering Mode show on your phone screen 4. Go to CDS info 5. Go to Radio info 6. then go to Phone1 (For the first IMEI No) 7. At the top there is a command line which begins "AT+" just type there "AT +EGMR=1,7,"IMEI_1" (Instead of IMEI_1 put your first IMEI No) 8. Hit send command 9. If you done just reboot the phone 10. If you change the second IMEI No then go to step 2 and select "Phone2" 11. And enter the code "AT +EGMR=1,10,"IMEI_2" (Instead of IMEI_2 put your second IMEI No) 12. Hit send command 13. Reboot your phone |
02-22-2018, 19:34 | #11 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | Quote:
