Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > OPPO / OnePlus
Old 07-01-2016, 20:06   #1 (permalink)
Crazy Poster
Member: 2425358
Thanks Meter: 53
Oppo F1Plus MT6755 imei repair
imei invalid of oppo f1 plus which runs with mt6755 cpu
mt 6755 supported in maui meta 9.1604
but cannot find nvram database files
i tried to get it from phone but cant root this device
somebody share mt 6755 bplgu modem file please
Old 09-03-2016, 18:09   #2 (permalink)
Member: 2529155
Sonork: robiking
Thanks Meter: 23
i helio mt6755 imei write problem help me
Old 09-04-2016, 14:37   #3 (permalink)
Member: 2601900
Thanks Meter: 519
did you try to root it using KINGO ROOT? if it works.write imei using mobile uncle tool
Old 09-11-2016, 22:08   #4 (permalink)
Crazy Poster
Member: 2425358
Thanks Meter: 53
i hv done it using at commands *#*#3646633#*#* thank you forum for no help
Old 09-16-2016, 17:15   #5 (permalink)
Member: 1845731
Thanks Meter: 741
oppo f1s a1601
cant work at command
i need flash file with db file(nv)
for invelid imei
The Following User Says Thank You to aryanmobile1989 For This Useful Post:
Old 04-13-2017, 09:57   #6 (permalink)
Crazy Poster
Member: 1690272
Thanks Meter: 5
lenovo a7020a48 imei repair help me
Old 04-13-2017, 14:09   #7 (permalink)
pranobcox's Avatar
Member: 2364514
Thanks Meter: 390
bro try
1. Rooted your MTK Android phone
2. Download and install Mobile Uncle Tools from Google play store.
3. Go to Engineer Mode and Select Engineer mode (MTK)
4. Go to Connectivity Tab and Select CDS information
5. Select Radio Information after that Select Phone1 (for the first IMEI)
6. At the top there is a command line which begins “AT+” just type there “AT +EGMR=1,7,”IMEI_1? (Put your first IMEI number number)
7. Hit send command and you will / may get a confirmation that "sent to mSend".
8. Now go back and select “Phone2? (for the second IMEI number)
9. At the top there is a command line which begins “AT+” just type there “AT +EGMR=1,10,”IMEI_2? (Put your second IMEI number)
10. Reboot your phone and check you IMEI number (Dial *#06#).
Must Read :- Latest Google play store for any Android device
lost-IMEI-Numbers
Must Read :- TheftSpy Anti-Theft app for Micromax A110 and other Android mobile
Second Method: -
1. Go to Engineering Mode with this code * # * # 3646633 # * # *
2. Type it on call pad
3. Engineering Mode show on your phone screen
4. Go to CDS info
5. Go to Radio info
6. then go to Phone1 (For the first IMEI No)
7. At the top there is a command line which begins "AT+" just type there "AT +EGMR=1,7,"IMEI_1" (Instead of IMEI_1 put your first IMEI No)
8. Hit send command
9. If you done just reboot the phone
10. If you change the second IMEI No then go to step 2 and select "Phone2"
11. And enter the code "AT +EGMR=1,10,"IMEI_2" (Instead of IMEI_2 put your second IMEI No)
12. Hit send command
13. Reboot your phone
Old 04-13-2017, 14:10   #8 (permalink)
ghr
Member: 1282787
Sonork: 100.1673491
Thanks Meter: 307
i done it many time with avengers box with meta mode
Old 04-17-2017, 07:55   #9 (permalink)
Member: 1228085
Sonork: 1111
Thanks Meter: 10
use miracle box imei repair 1000%
Old 04-17-2017, 08:16   #10 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
it can be simply repaired by SN Writer or MAUI Meta
if you are facing problem then use OTA to update firmware and then try again.
Old 02-22-2018, 19:34   #11 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
Originally Posted by pranobcox View Post
bro try
lost-IMEI-Numbers
Second Method: -
4. Go to CDS info
5. Go to Radio info
8. Hit send command
this method is not a permanent fix after full reset the imei will be lost again or revert to the original imei you must do it with boxes or find md ap mt6755
Page generated in 0.25274 seconds with 9 queries
