Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > OPPO
Old 02-04-2019, 10:40   #1 (permalink)
M.S.khan's Avatar
Member: 1813502
Sonork: 100.1623430
Thanks Meter: 169
oppo F5 Youth CPH1725 after testpoint sort set dead
Hi there
I also face the same problem that when short to remove pattern and frp job done but after that handset got dead.
I asked some help from Mr.Dynet and he replied to do this
And now my problem solved.
Thanks to Mr.Dynet
The Following 6 Users Say Thank You to M.S.khan For This Useful Post:
Old 02-04-2019, 15:13   #2 (permalink)
Ramicom's Avatar
Member: 76754
Sonork: 1580514
Thanks Meter: 36
thanks worked fine with me
The Following User Says Thank You to Ramicom For This Useful Post:
Old 02-17-2019, 21:48   #3 (permalink)
Member: 2894924
Thanks Meter: 2
Thank you for enlightening. There are a number of cases for Oppo F5 to open the pattern with the testpoint method, the phone is totally dead
The Following User Says Thank You to cROM95 For This Useful Post:
Old 02-19-2019, 14:30   #4 (permalink)
amh111515's Avatar
Member: 1857256
Sonork: 1650338
Thanks Meter: 91
Do what ?????? where is the picture ?
Old 02-19-2019, 16:00   #5 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,678
Dear Friend,
Just Reload/Refresh The Page Of Browser, If In Case Will Not Help So Click On This Link.
All Credit Goes To Solution Provider Not Me.
__________________
Read The Rules Carefully!!!
WBR
MyGSM World.
The Following 2 Users Say Thank You to MyGSM World For This Useful Post:
Old 03-09-2019, 03:10   #6 (permalink)
Member: 1777400
Sonork: 100.86843
Thanks Meter: 49
remove then jumper!
tnx alot works fine with me 1000000000%
Old 04-17-2019, 18:59   #7 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 450
now set shows only mtk port what do we next
The Following User Says Thank You to adnanali For This Useful Post:
Old 04-17-2019, 19:21   #8 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 450
This is a coil or a fuse kindly any expert about hardware please guide us
Old 04-18-2019, 11:42   #9 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 450
clean pcb Points
and make jumper ok now
Old 05-14-2019, 07:35   #10 (permalink)
Member: 850987
Thanks Meter: 4
very helpfull
since two days i was anxsus
good job bro
thanx a lot
Old 11-01-2019, 09:51   #11 (permalink)
Member: 2207624
clean pcb Points
Kindly help guys. After removing the resistor one of the left contacts is removed completely from the ground now I only have the right contact only( i mean where the resistor is soldered to the motherboard one contact the left one is removed. Can someone please help the resistor ways so that I can know the alternative place to short it
Old 11-01-2019, 10:19   #12 (permalink)
Member: 2933633
it's working with me thanks
Old 11-14-2019, 10:21   #13 (permalink)
Member: 2695389
Thanks Meter: 3
After resetting with test point and turning on the phone, the phone goes directly into recovery mode. Is there any solution? Oppo CPH1725 with Firmware version A.39.
Old 11-14-2019, 15:56   #14 (permalink)
jawad_anis's Avatar
Member: 726546
Sonork: 100.1578784
Thanks Meter: 530
wipe it from recovery if still same then refresh it problem will be solve
Old 11-14-2019, 15:57   #15 (permalink)
jawad_anis's Avatar
Member: 726546
Sonork: 100.1578784
Thanks Meter: 530
and check volume keys also maybe urs volume keys shorts that y going in recovery
Page generated in 0.34800 seconds with 7 queries
