04-17-2018, 08:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | ERROR "Max retrys(10) used @ 00000000 " I am claring icloud lock on MacBook Air A1466 Read SPI OK : Code: [17:08:31] -> Reading SPI starting ... [17:08:32] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [17:10:21] -> Reading data done. Stats: [17:10:21] -> Data: 8388608 bytes [17:10:21] -> Time: 108.37 s, avg speed: 77.40 KB/s [17:10:21] -> Verifying data starting... [17:12:04] -> Verifying data finished. Stats: [17:12:04] -> Read : 8388608 bytes, 0 sector retrys, 0 total retrys [17:12:04] -> Time: 103.65 s, avg speed: 80.93 KB/s [17:12:04] -> Reading SPI end. [17:12:05] -> Processing image... Image size = 8388608 Bytes Image type = Intel EFI Image detected Flash Components = 1 Flash Regions = 4 Number of Masters = 3 Region name | Base | Limit | Size Flash Descriptor | 00000000 | 00000FFF | 00001000 Platform Data | 00001000 | 00001FFF | 00001000 Intel ME | 00002000 | 0018DFFF | 0018C000 BIOS | 0018E000 | 007FFFFF | 00672000 Supported Flash Chips = 4 1F-4700 EF-4017 C2-2017 20-BA17 Firmware password = [SET/ACTIVE] Computer Model = MacBook Air (13-inch, Early 2015) Computer Zone = China Computer Birth Date = 25-MAR-2015 Computer SN = CPWPG9SWG940 Computer Order Number = MJVE2CH/A Computer Name = Khac?s MacBook Air iCloud account = YES iCloud account user = xxxxxxxxh iCloud account email = [email protected] iCloud Message = I'll pay u for my laptop back 04xxxxx iCloud Lock = [4 Digit] Recovery Boot Mode = locked Managment Engine = 10.0.35.1012 Code: [17:13:21] -> Management Engine export complete to: D:\Software\Boxes\HDBox\10.0.35.1012.me Info: 772393 bytes saved, 707538 FFh trail bytes from 1622016 total bytes discarded. Code: [17:13:36] -> Firmware lock removal... Firmware password = Removing & Cleaning area Space reclaimed = 185 bytes [17:13:57] -> iCloud lock removal... iCloud lock = [4 Digit] & Cleaning area Space reclaimed = 18564 bytes Enjoy! WRITE SPI (FULL) ERROR :-( Code: [17:14:09] -> Write SPI (FULL) starting ... [17:14:09] -> Checking Chip ID ... [17:14:10] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [17:14:10] -> Erasing SPI Chip(FULL-ERASE) ... [17:14:10] -> Writing Chip ... [17:15:50] -> Write Completed. Results: [17:15:50] -> Data: 5494528 bytes / 8388608 bytes (+52.67 % Speedup) [17:15:50] -> Time: 100.26 s, avg speed: 54.80 KB/s [17:15:50] -> Verifying data... [17:15:55] -> Max read retrys(10) used @ 00000000 Code: [17:18:31] -> Reading SPI starting ... [17:18:32] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [17:20:20] -> Reading data done. Stats: [17:20:20] -> Data: 8388608 bytes [17:20:20] -> Time: 108.39 s, avg speed: 77.39 KB/s [17:20:20] -> Verifying data starting... [17:20:25] -> Max retrys(10) used @ 00000000 [17:20:25] -> Reading SPI end. After this process, MacBook Now not turn on, it just shows Green Light on Charger Please let me know what to do ? LITTLE MASTER |
04-17-2018, 15:07 | #3 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | no . I didn't kept the power button pressed. MacBook was off. actually spi wasn't detecting the chip untill I disconnected the battery . I used charger to turn it on, then disconnected the battery to start the process. |
04-17-2018, 15:24 | #4 (permalink) |
Junior Member Join Date: Oct 2017 Location: Adelaide
Member: 2764998 Status: Offline Thanks Meter: 3 | You need to hold the power button when you start to read/write the SPI. try to do it with xlow SPD mode unplug the battery and continue by using the charger. |
The Following 3 Users Say Thank You to iFixSA For This Useful Post: |
04-18-2018, 05:21 | #5 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Thanks for Reply. i AM TRYING WITH POWER BUTTON PRESSED. Now When I Read Chip it shows its EMPLTY : Code: Now When I read Chip , I get this infor " " [13:39:43] -> Reading SPI starting ... [13:39:43] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [13:40:20] -> Reading data done. Stats: [13:40:20] -> Data: 8388608 bytes [13:40:20] -> Time: 36.94 s, avg speed: 227.08 KB/s [13:40:20] -> Verifying data starting... [13:40:42] -> Verifying data finished. Stats: [13:40:42] -> Read : 8388608 bytes, 0 sector retrys, 0 total retrys [13:40:42] -> Time: 21.29 s, avg speed: 393.94 KB/s [13:40:42] -> Reading SPI end. [13:40:42] -> Processing image... Image size = 8388608 Bytes Image type = EMPTY(FFh) "" I TRY TO LOAD THE ME FILE TO EFI , IT SHOWS THIS : Code: Opening: D:\Software\Boxes\HDBox\10.0.35.1012.me [13:46:56] -> Processing image... Valid Images should have between 1MB and 32MB.Stoping processing image. What to do now ? LITTLE MASTER |
04-18-2018, 06:02 | #6 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | I think I should have use the option " SAVE TO FILE " But Unfortunatly, I followed this picutre https://www.dropbox.com/s/083c950ybg...0V1.9.png?dl=0 Where on Step 3 , Arrow is appointed towards Export ME File :-( |
04-18-2018, 07:25 | #7 (permalink) |
Freak Poster Join Date: Feb 2018 Location: Spain
Member: 2806571 Status: Offline Thanks Meter: 23 | this tutorial was orientative for the version mac app 3.0. in the new version 3.1 different reading modes are activated. but there are videos of some different models and chips with version 3.1 http://forum.gsmhosting.com/vbb/f101...c-app-2369173/ |
04-19-2018, 00:16 | #8 (permalink) | |
Member: 1205146 Status: Offline Thanks Meter: 879 | Quote:
But can you guide me how to fix this now ? Because Chip is Erased. And I didn't saved the backup. I only saved ME File LITTLE MASTER | |
04-19-2018, 06:49 | #10 (permalink) | |
Member: 2806571 Status: Offline Thanks Meter: 23 | Quote:
https://ghostlyhaks.com/downloads/efi-repository | |
04-19-2018, 08:44 | #11 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Couldn't find the BIN File there. My EMC No. is 2925 I search file it shows two results : Code: MacBook Air Core i5 1.6 13 (Early 2015)1.6 GHz Core i5 (I5-5250U) 2925 MacBook Air Core i7 2.2 13 (Early 2015)2.2 GHz Core i7 (I7-5650U) 2925 |
04-19-2018, 09:30 | #12 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | Manage to find few files from internet, but i dont know how to edit them to work with my macbook. 820-00165-ALOCKEDCLION 820-00165-A-backup-cleaned |
04-19-2018, 15:15 | #13 (permalink) | |
04-20-2018, 02:35 | #14 (permalink) |
Member: 1205146 Status: Offline Thanks Meter: 879 | One of my friend ANDRZEJ from Poland helped me to make a file. He put my macbook serial on this file: Uploaded here : Logs : Code: [11:14:21] -> Detect SPI starting ... [11:14:21] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [11:14:21] -> Detect SPI finish. [11:14:25] -> Opening: C:\Users\Mr. India\Desktop\Andrej\820-00165-A.bin [11:14:25] -> Processing image... Image size = 8388608 Bytes Image type = Intel EFI Image detected Flash Components = 1 Flash Regions = 4 Number of Masters = 3 Region name | Base | Limit | Size Flash Descriptor | 00000000 | 00000FFF | 00001000 Platform Data | 00001000 | 00001FFF | 00001000 Intel ME | 00002000 | 0018DFFF | 0018C000 BIOS | 0018E000 | 007FFFFF | 00672000 Supported Flash Chips = 4 1F-4700 EF-4017 C2-2017 20-BA17 Firmware password = [NUKED] Computer Model = MacBook Air (13-inch, Early 2015) Computer Zone = China Computer Birth Date = 25-MAR-2015 Computer SN = CPWPG9SWG940 Computer Order Number = MJVE2CH/A Computer Name = MacBook Air ??? ?????? «Zoi» iCloud account = YES iCloud account user = Zoi Labro iCloud account email = [email protected] iCloud Message = ????????????? ??? 6978034778 iCloud Lock = [4 Digit] Recovery Boot Mode = locked Managment Engine = 10.0.35.1012 [11:14:29] -> iCloud lock removal... iCloud lock = [4 Digit] & Cleaning area Space reclaimed = 20793 bytes Enjoy! [11:14:31] -> iCloud lock removal... iCloud lock = [Not Locked] & Cleaning area Space reclaimed = 690 bytes Enjoy! Code: [11:14:38] -> Write SPI (FULL) starting ... [11:14:38] -> Checking Chip ID ... [11:14:38] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [11:14:38] -> Erasing SPI Chip(FULL-ERASE) ... [11:14:38] -> Writing Chip ... [11:18:13] -> Write Completed. Results: [11:18:13] -> Data: 5466624 bytes / 8388608 bytes (+53.45 % Speedup) [11:18:13] -> Time: 215.17 s, avg speed: 25.41 KB/s [11:18:13] -> Verifying data... [11:18:26] -> Max read retrys(10) used @ 00000000 Laptop has no screen now. When attach charger, fan spins , but has no image and no sound. ANY SUGGESTION ??? |
04-20-2018, 06:48 | #15 (permalink) |
Member: 2806571 Status: Offline Thanks Meter: 23 | Are you sure that your model is emc 2925 of 2015?.the picture corresponds to models from previous years. test yourself directly to the chip with the clamp.read and write,xlow sdp.or only full writte spi for connector isp red 1 you power on wait a few seconds and keep power off. for fan speed reset smc and pvram. Last edited by luistobcn; 04-20-2018 at 07:01. |
