03-09-2018, 15:58 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2007708 Status: Offline Thanks Meter: 3 | HDBOX ISP SPI Adaptor not workink A1502 EMC 2678 (Solved) YOUR PRODUCT DOES NOT CHARGE NEW MODELSI SEND YOU AND PICTURES AND ALWAYS NOT ANSWER Last edited by luistobcn; 03-12-2018 at 00:04. Reason: Solved the problem |
03-09-2018, 16:22 | #2 (permalink) | |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Quote:
Dear Bruce, I was about to contact you to ask for the picture in which you showed us how you connect. For only the first picture we can see well in th email. And in fact,you experience welcome in the forum. And hope the guide will help other customers also. Here is the troubleshooting link:Unlock iCloud Lock 4 digit / 6 digit | HDB Team. 1, How to check the way to connect well. 2,How to help the ISP adaptor to get the control from the chip on the board Thanks & Best Regards! HDB Team | |
03-09-2018, 17:19 | #3 (permalink) |
Member: 2007708 Status: Offline Thanks Meter: 3 | I have to try all with red light and blue led and with the battery and without battery with the charger and without the charger with both pieces number 2 and 3 sa does not work i have followed all your instruction and sa gives nothing you have no video with a recent models and i am sending you photos |
03-09-2018, 17:34 | #4 (permalink) | |
Dear Sir, Here is the guide video made by our customer for the A1502. It is more detailed for this moudule. http://forum.gsmhosting.com/vbb/f101...other-2352610/. Thanks & Best Regards! HDB Team | |
03-09-2018, 21:25 | #9 (permalink) | |
Freak Poster Join Date: Feb 2018 Location: Spain
Member: 2806571 Status: Offline Thanks Meter: 23 | Quote:
now you have 2 led blue and red press power button, wait for power on. Press the power button again, and keep pressed, throughout the process. when the macbook goes out. You start the process software. Start mac app-detect spi-save file-clear firmware look/ and icloud-Writte spi full. after you reset pvram for 3 time.. this with cable supplied in HDbox kit.For me working in all. some chip only with 5 wired.some process.but only 5 wired. https://www.youtube.com/watch?v=M7swIlbYSmE&t=40s I test in a1502 2013-2014-2014 a1398 2014-2015 a1706 2016-17 a1708 2016-17 all it work,with mine process.with chargerd and battery,only chargerd,only with battery. Is easy a fast. You have to think that in identical models and year apple can have different efi chips. Last edited by luistobcn; 03-09-2018 at 21:30. | |
03-09-2018, 21:45 | #11 (permalink) | |
another from remote user. both have different efi chip readings. you have to try different options. With time you can remove the block with HDbox. for me is the best. | |
03-09-2018, 22:34 | #12 (permalink) |
Member: 2806571 Status: Offline Thanks Meter: 23 | I have also found another type of blocking in a1706. Encryption of ssd or hdd(filevault in mac OS)the home screen is different, request apple id and password. In other models you change SSD or HDD, problem solved. but in new models with touchbar a1706-a1707 and macbook a1534. The SSD is nand flash type soldered to the logicboard. in my case the a1706 with red connector number 1 and hdbox unlocked the filevault. Note that the firmware of the chip, is changed by apple in updates, and even having the same chip and model you can find a different firmware. Last edited by luistobcn; 03-09-2018 at 22:40. |
03-09-2018, 22:41 | #13 (permalink) |
Member: 2007708 Status: Offline Thanks Meter: 3 | (thank you for your help but it does not work for me i followed instructions I put the interface n.2 led red led bleu power pc ok shutdown pc after run software your interface has wires its you who modified it ) and for the MacBook air flex does not work impossible to read the ERROR CHIP ID :00 00 00 00 |
03-09-2018, 23:08 | #15 (permalink) | |
Do you update to efi software 3.0? | |
