03-09-2018, 23:11 | #16 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2007708 Status: Offline Thanks Meter: 3 | |
03-09-2018, 23:47 | #20 (permalink) | |
Freak Poster Join Date: Feb 2018 Location: Spain
Member: 2806571 Status: Offline Thanks Meter: 23 | Quote:
you use the flex cable that comes in the ips adapter of hdbox. | |
03-10-2018, 00:04 | #22 (permalink) | |
https://www.dropbox.com/s/yip9er6ax8...02015.png?dl=0 you put the connector 1 red.whe you see led red in isp is ok. Then put the isp adapter to the hdbox, now you will see two blue and red led. please tell me in this case if you turn on the macbook and the fan works | |
03-10-2018, 00:30 | #25 (permalink) |
Member: 2806571 Status: Offline Thanks Meter: 23 | Ok,now save backup a follow the picture. https://www.dropbox.com/s/1p5rmkktbt...13%29.png?dl=0 It is fast, but you have to press -clear firmware and icloud-after write full spi |
03-10-2018, 00:32 | #26 (permalink) |
Member: 2007708 Status: Offline Thanks Meter: 3 | THE RED CONNECTOR ON I AM READING TO READ THE INFORMATION Didn't lock this Mac? Go to www.icloud.com/find to get the PIN to unlock it. iCloud Lock = [4 Digit] Recovery Boot Mode = locked Managment Engine = 10.0.35.1012 [00:23:43] -> iCloud lock removal... iCloud lock = [4 Digit] & Cleaning area Space reclaimed = 34434 bytes Enjoy! [00:23:49] -> iCloud lock removal... iCloud lock = [Not Locked] & Cleaning area Space reclaimed = 701 bytes Enjoy! [00:24:02] -> Firmware lock removal... Firmware password = Removing & Cleaning area Space reclaimed = 1613 bytes [00:24:23] -> Firmware lock removal... Firmware password = No Password, Cleaning area Space reclaimed = 0 bytes ICLOUD NOT REMOVE PLEASE how I do |
