02-20-2019, 01:52 | #19 (permalink) | |
Junior Member Join Date: Feb 2018
Member: 2807080 Status: Offline Thanks Meter: 24 | Quote:
[18:50:12] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [18:50:12] -> Detect SPI finish. [18:50:16] -> Reading SPI starting ... [18:50:17] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [18:50:58] -> Reading data done. Stats: [18:50:58] -> Data: 8388608 bytes [18:50:58] -> Time: 41.53 s, avg speed: 201.98 KB/s [18:50:58] -> Verifying data starting ... [18:51:27] -> Verifying data finished. Stats: [18:51:27] -> Read : 8388608 bytes, 0 sector retrys, 0 total retrys [18:51:27] -> Time: 28.77 s, avg speed: 291.62 KB/s [18:51:27] -> Reading SPI done [18:51:28] -> Processing image... Image size = 8388608 Bytes Image type = Unknown format. Please consider sending it to [email protected] for further tests. Thank you. | |
The Following User Says Thank You to Ioscellhardware For This Useful Post: |
02-20-2019, 02:25 | #20 (permalink) | |
[19:23:23] -> Detect SPI starting ... [19:23:24] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [19:23:24] -> Detect SPI finish. [19:23:26] -> Reading SPI starting ... [19:23:26] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [19:24:08] -> Reading data done. Stats: [19:24:08] -> Data: 8388608 bytes [19:24:08] -> Time: 41.53 s, avg speed: 201.98 KB/s [19:24:08] -> Verifying data starting ... [19:24:37] -> Verifying data finished. Stats: [19:24:37] -> Read : 8388608 bytes, 0 sector retrys, 0 total retrys [19:24:37] -> Time: 28.76 s, avg speed: 291.63 KB/s [19:24:37] -> Reading SPI done [19:24:37] -> Processing image... Image size = 8388608 Bytes Image type = Unknown format. Please consider sending it to [email protected] for further tests. Thank you. | |
02-20-2019, 14:54 | #21 (permalink) |
Member: 2807080 Status: Offline Thanks Meter: 24 | Error to read info I tried to read the bios chip information from macbook 2015 A1502 EMC 2835 but hdbox does not read the EFI information. says Image type = Unknown format then try to erase and write with WRITE SPI (FULL) and the hdbox deleted and wrote but now my macbook is dead some help? hdbox team does not answer any expert here? I think I need to rewrite an original file. Somebody has it [06:02:58] -> Connecting Mac App ... Ok [06:02:58] -> Box Running App: Apple EFI 3.1B (00000009) [06:03:04] -> Detect SPI starting ... [06:03:05] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [06:03:05] -> Detect SPI finish. [06:03:08] -> Reading SPI starting ... [06:03:09] -> CHIP ID: 00 C2 20 17 (MX25L6405D - 8 MB) [06:03:50] -> Reading data done. Stats: [06:03:50] -> Data: 8388608 bytes [06:03:50] -> Time: 41.58 s, avg speed: 201.76 KB/s [06:03:50] -> Verifying data starting ... [06:04:19] -> Verifying data finished. Stats: [06:04:19] -> Read : 8388608 bytes, 0 sector retrys, 0 total retrys [06:04:19] -> Time: 28.78 s, avg speed: 291.46 KB/s [06:04:19] -> Reading SPI done [06:04:19] -> Processing image... Image size = 8388608 Bytes Image type = Unknown format. Please consider sending it to [email protected] for further tests. Thank you. |
02-20-2019, 21:33 | #22 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, Seeing this bit in your log: [06:04:19] -> Verifying data finished. Stats: [06:04:19] -> Read : 8388608 bytes, 0 sector retrys, 0 total retrys Tells me that the connection between HDBOX and your Mac Chip is GOOD, but the content inside the chip is NOT THAT good. Please PM us your computer Serial Number. We are gonna search a very close donor file for your computer, and prepare it for you. After you receveive it you have to write that one to your mac, and after that perform an NVRAM/PRAM reset. All Should Be working perfectly. -Or- If you have an working backup of the chip content also write that back, the mac should start. Right now it cannot start cause the image inside your computers chip is not good. We are gonna fix that! Best Regards, HDBOX Support Team. |
The Following 2 Users Say Thank You to HDB For This Useful Post: |
02-21-2019, 03:12 | #23 (permalink) | |
Member: 1300847 Status: Offline Thanks Meter: 547 | We already got the computer info. And will offer the file to you ASAP. To protect your computer info. We have delete the info on forum. Thanks & Best Regards! HDB Team Quote:
The Following User Says Thank You to HDB For This Useful Post: |
02-21-2019, 04:05 | #24 (permalink) |
Member: 2807080 Status: Offline Thanks Meter: 24 | Thank you for you fast support I will be here wating for it this is mine email [email protected] I would like you send me an email thank you so much I’ll wating |
02-22-2019, 00:06 | #25 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, I have sent you an PM with link to download the file prepared for your mac. The file you will write to your mac SPI, and your SN should remain same, but no more iCloud / firmware password on it. After flash please consider performing an NVRAM / PRAM reset ( and maybe even an SMC reset - required only in very rare cases ) https://www.macworld.com/article/288...m-and-smc.html And to flash this file, 1-simply open HDBOX Manager like before, connect to chip, and click detect ID couple of times to make sure communication is stable, 2-Click open file, select the file, 3-Click Write Spi (FULL) for full erase and write, 4-There is no 4! just reset the mac, now should be working, and if not, do the NVRAM/PRAM reset. If still not work we will search another donor file, but this one was from same EMC with your computer, so should be working 100%. Best regards HDBOX Support Team. |
02-22-2019, 06:33 | #26 (permalink) |
Member: 2807080 Status: Offline Thanks Meter: 24 | I have flashed the file HDBOX make all the job but Macbook not turning on maybe something is wrong the MacBook only turning on the fan and not screens the bios chip is good coz HDBOX flashed the file but Macbook not turning on my. Maybe testing other knack up Thank you for reply |
02-22-2019, 14:16 | #27 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Ok, Two things: 1) Did you perform the NVRAM/PRAM reset? 2) The light on charger, is it Amber , and switching to Green when fully charger? ( This will confirm the SMC is alright ) |
02-23-2019, 00:04 | #28 (permalink) |
Member: 2807080 Status: Offline Thanks Meter: 24 | yes sir. the light is green just like when it is fully charged i did all what you told and same bro |
02-26-2019, 01:01 | #29 (permalink) | |
Member: 2807080 Status: Offline Thanks Meter: 24 | solved Quote:
04-18-2019, 08:23 | #30 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 956861 Status: Offline Thanks Meter: 27 | can the hdbox team create an application in the box to unlock the mobile phones or a calculator to unlock the phone network without pc ? |
The Following User Says Thank You to ecrotek For This Useful Post: |
