06-18-2017, 11:59 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello your situation is very similar to ours when we first tested IOS8 disabled devices ( was also an IPAD ). If you have previously synched this iPad with your computer, simply perform a restore from your that backup and everything should be fine, but if you do not have a backup, then keep reading. What we did to fix IOS8 disabled was like this:
We had to this quite a few times until we got it right, but we did recover that device and we hope you will be able to do so also. |
06-19-2017, 17:15 | #6 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, I talked with my partner as he was with me when we played with our IOS8 test ipad, and he remembered me that we used DFU MODE and not recovery mode. Basically put ipad into DFU mode, perform restore from a downloaded IPSW file and at random interval unplug the cable and fail the process. We did it 3 times and our ipad got out of disabled state after 3 failed restores and a complete one. For your convenience here is how to put IOS device into DFU mode:
Best regards, HDB Team EDIT: To make something very clear about "remove the cable at random interval intervals" you should only remove the cable while iTunes is showing you "Restoring iPad software" and NOT before or after that stage. Also, first try a full restore from DFU mode and only ifiPad is still disabled after that complete restore from DFU mode, then perform two more restores and fail them at about 10% and 90% during "Restoring iPad software" phase. After those two failed atempts do a complete restore again and iPad should be like a brand new one. Best of luck! Last edited by HDB; 06-19-2017 at 17:32. |
The Following User Says Thank You to HDB For This Useful Post: |
06-20-2017, 00:02 | #7 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Italy
Member: 329458 Status: Offline Thanks Meter: 153 | But now my iPad is like new one. Restored to latest iOS release. BUT, my interest is to UNLOCK device and put it OUT of disabled mode. Restore iPad to default settings was my latest chanche... |
07-03-2017, 06:34 | #8 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, Like i said, we used DFU restore method to kick our IOS8 device out of disabled state. Restoring from DFU and stoping the process at random times will wipe your user lock on that iPad and also remove disabled mode. It worked for us, but we had to perform a couple of DFU restores to get it out of disabled state. Hoping you will find the right moment and recover your IOS8 device, HDB-Team.com support |
