06-03-2018, 19:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Germany
Member: 1087322 Status: Offline Thanks Meter: 173 | Macbook a1466 emc 2632 dead? did macbook a1466 emc 2632. wanted to remove icloud. the hdbox crashed. since the laptop is no longer on and I get no connection with the box anymore? Please help. B.r Afghanboy |
06-04-2018, 08:36 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Dear Sir, The computer should be just fine. Just booting A1466 is some weird after using ISP adaptor. In our tests on 1466 to power it up after using ISP adaptor was like this: 1) remove ISP adaptor and connector from board, remove charger, remove internal battery 2) Wait about 5-10 seconds for any capacitors to discharge 3) Then connect charger, and laptop should power on himself, if not press power to start it 4) Now connect Internal Battery and after a reboot MacOSX will detect the battery and everything should be fine. The only cases when mac should be dead is you read an not valid image from chip and press write button. Or you stopped the write process in middle of it. Thanks HDB Team |
06-04-2018, 10:20 | #3 (permalink) |
Member: 1087322 Status: Offline Thanks Meter: 173 | Hello, Thank you for your answer. yes it crashed while writing. I tried everything as you wrote. Unfortunately, the laptop is no longer on. Is there a way to revive it? B.r Afghanboy |
06-06-2018, 15:08 | #8 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Please give us your email account and send it to "[email protected]". We will send the file to you via email. Thanks HDB Team |
06-10-2018, 18:10 | #10 (permalink) |
Member: 1087322 Status: Offline Thanks Meter: 173 | hello hd team (red light should turn on the ISP adapter, if the CHIP power is detected) there is no red led I have the red connector 1 infected what am I doing wrong? |
