10-27-2017, 14:21 | #16 (permalink) | |
No Life Poster Join Date: May 2010 Location: Shenzhen, China
Member: 1300847 Status: Offline Thanks Meter: 547 | Quote: Dear Sir, If possible,could you describe the problem more clear.Such as, The IOS version of the phone? The Apple Moudule NO? And what happened during you use the box. We understand that unlocking is not easy. Clear description will help us to work it out together. Thanks & Best Regards! HDB Team | |
12-04-2017, 13:01 | #18 (permalink) |
Registered User Join Date: Mar 2010
Member: 1267997 Status: Offline Sonork: cesar Thanks Meter: 0 | iphone is disabled all the iphones I'm putting to remove the password are getting disabled! 4,5,5s, 5c, 6 ... and versions other than OS, did not understand the operation of your box. I do not think it works! |
12-08-2017, 23:49 | #19 (permalink) |
Member: 1300847 Status: Offline Thanks Meter: 547 | Hello, 1) For Iphone4 (Or any other iphone/ipod/ipas still which are also on Ios 7.X ) is perfectly fine even if phone disabled, to check that codes are properly tested, turn off privacy switch, and after a code is entered phone should vibrate indicating that code was tested. 2) For devices with IOS8.0 - IOS8.1 we have the yellow adaptor to test codes in batch of 3. Using adaptor and HDBOX the codes can be tested without opening the phone, unlike other tools that ask to open the phone, solder wires, bla bla. 3) For Any other IOS versions, there is a solution only if phone is jailbreaked and have open SSH installed with default password. All this sollutions are working for ever using our HDBOX and do not require any activations or renewals or whatever. 4) This one is close by apple now. But i listed here none the less as some people still have phones prepared. Prepared phones for unlock = Any apple devices which were flashed with IOS10.3.x or IOS11 using software 3U toold (3u.com) and "Preserve user option data" check box was ticked during flashing. The device should display an messaga "Press home to recover the data" ( Added in 3.x version of our IOS APP ) 5) For IOS6,5,4, and earlier, simply boot device into DFU and perform an restore, this will delete the code but sadly, the data on the phone will be also lost. All previous methods will protect the data on phone. ( You do not need HDBOX for phones in this category ) But if your phone does not fall under this 5 big categories, and you suspect the phone is having icloud account on it, you can use our friends at unlockbylogs.com and use their "iCloud Remove Worldwide for iPhone | iPad (Clean) 3 - 8 Days" and after icloud is removed from that phone, simply restore it from DFU mode. I hope i make clear what iphone / ipad / ios are supported, and if you need any other informations, we will gladly help you with them! Best regards, HDBOX Support Team. |
12-22-2017, 15:18 | #21 (permalink) | |
Apple have debug that part already.So that function do not work anymore .Please note it. Other funciton of our HDBox still work well! Thanks & Best Regards! HDB Team | |
01-02-2018, 23:11 | #22 (permalink) |
No Life Poster Join Date: Aug 2006 Location: melbourne australia thailand Age: 48
Member: 338192 Status: Offline Sonork: 1678261 Thanks Meter: 154 | Enjoy HDB-team.com [09:03:53] -> Starting Iphone App ... OK. [09:03:53] -> Reading saved sessions ... 1 saved sessions found. [09:03:53] -> Running: iPhone App 2.5d [09:03:59] -> ======== Phone details ======== [09:03:59] -> Access: Standard Access [09:03:59] -> IOS : 10.3.3 (supported) [09:03:59] -> SN : F78MG14LFYW8 [09:03:59] -> UDID : b8a33dc5b9d19354d07a25652a62915eeb300e59 [09:03:59] -> Model : MG132X [09:03:59] -> Details : iPhone 5c: 8 GB white [09:03:59] -> Zone : Australia, New Zealand [09:03:59] -> Date : 25-MAR-2014 [09:03:59] -> ========================= [09:04:40] -> Using 20% for sensor settings. [09:04:41] -> Testing: 0000 [09:04:47] -> Testing: 0001 [09:04:54] -> Testing: 0002 [09:05:00] -> Testing: 0003 [09:05:06] -> Testing: 0004 [09:05:13] -> Testing: 0005 [09:05:19] -> Testing: 0006 [09:05:21] -> Code found: 0006 [09:05:21] -> Sensor Level: 3456, Prev Level = 9728 [09:05:21] -> === RUN STATS === [09:05:21] -> Total Codes : 10000 [09:05:21] -> Tested Codes : 6 (0.06%) [09:05:21] -> Skiped Codes : 0 (0.00%) [09:05:21] -> Codes Left : 9994 (99.94%) this box not working fully bur**** how cam peopels cheat ing like that i put code 6666 read whats sutubit box says |
01-02-2018, 23:13 | #23 (permalink) |
Member: 338192 Status: Offline Sonork: 1678261 Thanks Meter: 154 | hdb team pleases dont cheating like that plus phone its disayble now what going on HDB TEAM same one tell me what going on ???? |
07-25-2018, 15:55 | #26 (permalink) | |
Sorry for the late reply. Was quite busy to fix other issue. If you had experience with Apple,then you should know they are creazy with their security and debug soon once we found the hole. And if you check the trhread carefully, then you have found info such as ---------------------------------------------------------------------- Quote: Originally Posted by mohs_shahid Hi i have iphone 7 disabled with ios 10.3.3 will this work on this If the phone have not flashed before 7th Oct(2017),the update could not work on it anymore then. | |
07-25-2018, 16:22 | #28 (permalink) | |
I think you mentioned the APPLE computers and laptops on the title also ,right? If there is any issue on it. Please discribe the operations and issues. Our tech support will offer you guide. Thanks & Best Regards! HDB Team | |
