03-19-2017, 17:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | we need more information pls i read your manual about hd and show some video. i think it's going to change theam and think to repair phone. but not sure still now. so, pls more info about HDB. 1. it's standalone software ? and which CPU base ( mtk, spd, qcomm) ? 2. support current android base phone like samsung, lg, htc, sony, huawei, oppo, xiaomi ? 3. support secure boot ? 4. need credit every function like frp, sp unlock .? 5. support imei repair (security repair) ? 6. need yearly activation ? 7. support service provider unlock (sp unlock) china base phone ? and last 7. how can we obtain ( buy HDB ) , if there are no resellar in any country? i appreciated if reply. good wishes and long live HDB future. thanks with best regards, mahir ashab |
03-20-2017, 02:50 | #2 (permalink) | |
Freak Poster Join Date: Mar 2012
Member: 1738539 Status: Offline Thanks Meter: 11 | Quote:
Thanks very much for all those questions. It is also guide for us to know what customers care about. We will organize all those and let you have a better idea about our HDBox. Thanks &a best regards! HDB team | |
The Following User Says Thank You to daneremail For This Useful Post: |
03-20-2017, 09:54 | #3 (permalink) |
Member: 1738539 Status: Offline Thanks Meter: 11 | [QUOTE=daneremail;12405137]Dear Mahir, Thanks very much for all those questions. 1) it is stand alone software. And is working no matter what processor the phone have. Also the hdbox can function by itself without computer for most functions 2) all android handset are supported. The only handsets that are not working are the ones modified much from base android. But as long as you can 4 batches of 5 codes and the timeout is still 30 seconds between batches then it will work. 3) we do not touch the flash of the phones so we do not care about secure or not secure boot. However, we do use ADB and secure ADB is supported. We only use adb as a faster mean to remove user lock if the phone got add active 4) all funtions implemented are standalone with life time activation. You can use it as much as you want for as long as you want. 5) at this stage we do not offer sp unlock or imei repair, we are forensic tool, aimed at removing user locks without dataloss. 6) lifetime activation. No need anual reactivation. 7) see point 5 8) you can either buy directly from us, but we suggest to you to check our website, where to buy, page and there you find a list of our resellers. And select a reseller / distributor in your country if we have one already. If we do not, maybe you would like to become one |
03-31-2017, 08:22 | #5 (permalink) | |
Member: 1128573 Status: Offline Thanks Meter: 242 | Quote:
FRP - Alternative way In case the storage disk does not present itself,fallow this simple alternative guide: 1) Connect HDBox to your computer, select FRP tool, and copy this bypass.apk to your computer. 2) Grab any usb sticks with size bigger than 1GB and format it to FAT32, then copy bypass.apk to it 3) Connect the USB stick with the phone using an OTG cable, and now you can install the bypass.apk from the stick to bypass the FRP lock 4) Keep the stick around, as you can use it on as many phones as you like, as long as they still do not have the security vulnerability patched. | |
