Old 07-09-2018, 20:12   #1 (permalink)
Member: 2501288
Thanks Meter: 256
eft dongle not detect any device!!
i tried with mtk device and qualcomm
here i tried to read info vdf900 stop at 11% even i install different drivers version, i dont know if i miss some thing
Old 07-09-2018, 20:24   #2 (permalink)
Member: 2501288
Thanks Meter: 256
pleas i need solution asap
Old 07-09-2018, 22:29   #3 (permalink)
Member: 2501288
Thanks Meter: 256
oppo r9s plus
Send boot.......OK
Get Info.....
Detecting Device info.......OK
Product: OPPO
Device Model: CPH1611
Sw Internal:
Build Date: Fri Apr 13 00:47:23 CST 2018
Chip Ver:
Android Version: 6.0.1
Architecture: arm64-v8a
Screen Lock Reset (Encrypted Data).............OK
All Done By EFT Dongle
The Following User Says Thank You to Steve-1 For This Useful Post:
Old 07-09-2018, 23:42   #4 (permalink)
Thanks Meter: 13,158
try to select firehose manually and try again
The Following User Says Thank You to easy-team For This Useful Post:
Old 07-09-2018, 23:45   #5 (permalink)
Member: 2501288
Thanks Meter: 256
i have firmware read by infinity , and the XML not supported by eft, do you have pleas firmware to repair this VFD900 stuck at logo ?
Old 07-10-2018, 00:16   #6 (permalink)
CHEZRACHID's Avatar
Member: 136492
Thanks Meter: 194
same problem for me phone doesn't connect only with eft
Old 12-25-2018, 19:36   #7 (permalink)
Member: 2640427
i have this problem too. can't do anything to qualcomm devices.
i tried too many drivers and selected the right port but not detected
is this win 10 x64 bit problem or what
Old 01-14-2020, 04:35   #8 (permalink)
Member: 2791378
I cant post images.
Works for me. Make sure to use firehose and uncheck new and if it fails for some reason disconnect the phone power it off and put it into EDL mode again fresh before trying again.
The Following User Says Thank You to Raroshack For This Useful Post:
Page generated in 0.26277 seconds with 8 queries
