09-21-2019, 11:49 | #109 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Contact us https://www.facebook.com/eftdongle |
The Following User Says Thank You to easy-team For This Useful Post: |
09-23-2019, 01:39 | #110 (permalink) |
Junior Member Join Date: Apr 2016 Location: philippines
Member: 2562120 Status: Offline Sonork: [email protected] Thanks Meter: 1 | eft team plz add frp oppo a3s and samsung a10 a20 a30 binary huawei mrd-lx2 |
The Following User Says Thank You to black_hunter_88 For This Useful Post: |
09-23-2019, 13:02 | #113 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | EFT PRO 1.4 Failed to reset FRP on G531F via FRP Section Code: Searching for Samsung ODIN protocol.....Detected {COM9} Connecting to device.....OK Device Model.....SM-G531F Reading PIT.....OK Flashing [data].....OK Rebooting device.....OK Operation ID: BC523EF109B0FA05FCC61C158561F81B Elapsed time 00:04 -- Version 1.4 |
09-23-2019, 13:06 | #114 (permalink) |
Member: 2683134 Status: Offline Thanks Meter: 59 | Both Operations Failed to Reset FRP on G531F U1 via EFT PRO v1.4 Bypass Protections Code: Analyzing file.....OK Searching for Samsung ODIN protocol.....Detected {COM9} Connecting to device.....OK Device Model.....SM-G531F Reading PIT.....OK Flashing [data 1].....OK Rebooting device.....OK Waiting for device.....OK Reading device info.....OK Serial Number: RV8G70BJ5AX Device bootloader: G531FXXU1AOGB Device warranty bit: 1 Device Firmware: G531FXXU1AOGB Android version: 5.1.1 Device SDK: 22 Device data encryption: unencrypted Device Hardware: pxa1908 Device CPU: armeabi-v7a Device Factory: samsung Device Model: SM-G531F Device IMEI: Root status.....Rooted { Adb direct } Resetting FRP.....OK Operation ID: 190277BA5F5CC527A57AA47E54589E43 Elapsed time 01:06 -- Version 1.4 |
The Following User Says Thank You to Love_InsPeXtor For This Useful Post: |
09-25-2019, 12:57 | #119 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Very good update and especially great work with the firmware BOARD FIRMWARE FLASHING IN UPGRADE MODE BY EFT PRO, excellent, great work to the entire team of eft. EFT dongle / EFT PRO the best |
09-25-2019, 14:29 | #120 (permalink) |
Freak Poster Join Date: Mar 2015 Location: Azerbaijan/Masalli
Member: 2355681 Status: Offline Thanks Meter: 78 | redmi note 7 Operation : Xiaomi Boot Patch Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.0.9.9 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_022]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Reading Auth Blob...OK Blob : AQAAAD0BAAAuTsYEbDqc61DwVqfOsJFv9i5xrw Getting Auth Data...Connecttion to Auth App Failed! Run Auth App if not running, or restart Auth App! Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.7 |
