01-30-2020, 02:57 | #136 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | after writing combination, eft dongle shows phone unlocked but phone restarts and it is stuck at kernel panic upload mode, but not unlocked. need solution..? |
02-04-2020, 12:15 | #137 (permalink) |
Freak Poster Join Date: Dec 2015 Age: 46
Member: 2496790 Status: Offline Thanks Meter: 11 | hi can you pls tell me if there is an option to root samsung a107f cuase i tryed to make root with the same ap file that is on the device 1. i puted also in ap and bl tab the corect file and flash it after i had open oem it flashed it well but could not get root permision pls guide as how can i root a10s ? |
02-13-2020, 15:39 | #138 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Ghana takoradi
Member: 793188 Status: Offline Thanks Meter: 55 | Huawei mate 10 frp dond without downgrade Extracting files.....Done Waiting for device to connect.....Found {COM88} Opening Port.....OK Writing xloader.....OK Writing usb xloader.....OK Writing fastboot.....OK Rebooting to fastboot.....OK Connecting Fastboot ....... Connecting Fastboot .......Ok Model Phone: ALP-L29 SW: :ALP-L299.0.0.177(C185E2R1P12) Android Version: 9 SN: QMU7xxxxxxxx161 IMEI: 86621xxxxxxxxx9 IMEI: IMEI1:86xxxxxxxxxx IMEI: MEID:A000xxxxxxxxxx Lock state: FBLockState:UNLOCKED USERLockState:LOCKED Boot info: unlocked battery: 0 Frp Erase ...............OK Erase Done , The Device Will Reboot And Factory Reset Reboot ...............OK By EFT Dongle OK |
04-29-2020, 13:43 | #146 (permalink) |
Member: 2496790 Status: Offline Thanks Meter: 11 | hi i have a problem to bypass knox i have samsung sm-j250f security u2 revision 3 i have took out the boot file from the AP in the same software and flashed it on the phone i made the EFT FILE for (enable adb) also for root also for bypass knox security in all the software repeats the following LOG ******** Opening Port COM297...........OK Verifying Download Mod OK Initialization.......OK Reading Phone Partitation Table........OK Partition Size : 8192 Unpak pit .......OK FLASHING FIRMWARE TO PHONE..... Writing: boot.img.......OK FLASHING DONE! Rebooting PDA TO NORMAL MODE...... ERROR : phone unable to accept data, wrong command sent..OK ********* after flashing the knox bypass file .even though i see this massage it shows in the phone more app then what was in usual knox mode. so the file made something. but after rebooting it turning back to same knox mode what is the proceedure the bypass it cuase i dont have adb enable ( but usb debuging is anabled but the computer can not see it ) for sure i dont have driver issue . pls advise |
05-11-2020, 00:01 | #147 (permalink) |
Member: 2406539 Status: Offline Thanks Meter: 101 | can you help me to unbrick Mate 20 Lite (SNE-LX1), it's showing only red light blinking on top. i have flashed board firmware successfully but phone doesn't turn ON, it goes straight to fastboot mode after flashing and screen remains blank all the time. Connecting to device (HUAWEI USB COM 1.0).......OK Preparing Firmware.......OK Flash: sec_usb_xloader.img..............OK Preparing Firmware.......OK Flash: sec_usb_xloader2.img..............OK Preparing Firmware.......OK Flash: sec_fastboot.img..............OK Connecting Fastboot_ ............OK flash : huawei_crc_check..........OK flash : xloader..........OK flash : huawei_crc_check..........OK flash : ptable..........OK flash : huawei_crc_check..........OK flash : fastboot..........OK flash : huawei_crc_check..........OK flash : vector..........OK flash : huawei_crc_check..........OK flash : dts..........OK flash : huawei_crc_check..........OK flash : dto..........OK flash : huawei_crc_check..........OK flash : fw_lpm3..........OK flash : huawei_crc_check..........OK flash : sensorhub..........OK flash : huawei_crc_check..........OK flash : fw_hifi..........OK flash : huawei_crc_check..........OK flash : teeos..........OK flash : huawei_crc_check..........OK flash : recovery_ramdisk..........OK flash : huawei_crc_check..........OK flash : recovery_vendor..........OK flash : huawei_crc_check..........OK flash : recovery_vbmeta..........OK flash : huawei_crc_check..........OK flash : cache..........OK flash : huawei_crc_check..........OK flash : kernel..........OK flash : huawei_crc_check..........OK flash : ramdisk..........OK flash : huawei_crc_check..........OK flash : hhee..........OK flash : huawei_crc_check..........OK flash : vbmeta..........OK flash : huawei_crc_check..........OK flash : odm..........OK flash : huawei_crc_check..........OK flash : nvme..........OK flash : huawei_crc_check..........OK flash : trustfirmware..........OK flash : huawei_crc_check..........OK flash : modem_fw..........OK flash : huawei_crc_check..........OK flash : modemnvm_update..........OK flash : huawei_crc_check..........OK flash : modemnvm_cust..........OK flash : huawei_crc_check..........OK flash : modem_om..........OK flash : huawei_crc_check..........OK flash : modemnvm_img..........OK flash : huawei_crc_check..........OK flash : isp_firmware..........OK flash : huawei_crc_check..........OK flash : userdata..........OK flash : huawei_crc_check..........OK flash : system..........OK flash : huawei_crc_check..........OK flash : vendor..........OK flash : huawei_crc_check..........OK flash : product..........OK flash : huawei_crc_check..........OK flash : version..........OK flash : huawei_crc_check..........OK flash : splash2..........OK flash : huawei_crc_check..........OK flash : frp..........OK flash : huawei_crc_check..........OK flash : oeminfo..........OK flash : huawei_crc_check..........OK flash : secure_storage..........OK flash : huawei_crc_check..........OK flash : modem_secure..........OK flash : huawei_crc_check..........OK flash : hisee_img..........OK flash : huawei_crc_check..........OK flash : hisee_fs..........OK flash : huawei_crc_check..........OK flash : hibench_data..........OK flash : huawei_crc_check..........OK flash : efuse..........OK Reboot ...............OK |
