Old 04-15-2019, 16:33   #1 (permalink)
Member: 2882521
Thanks Meter: 34
G570F frp not removed.
G570 Frp not removed.
https://imgur.com/a/dJtxzCd
Old 04-15-2019, 16:52   #2 (permalink)
Member: 2669781
Thanks Meter: 1,839
Hi sir,
Your device is OEM locked, won't accept customized data, you have to use engineering images/Combination
If your file is U1, use the following Comfile..
https://shell.boxwares.com/Download.aspx?L=16
As you may try EMMC UART method, on the same tab..
Good luck
Old 04-15-2019, 21:12   #3 (permalink)
Thanks Meter: 21,230
Downgrade to Android 7.0 then do it again while choosing model j200G
Page generated in 0.18468 seconds with 8 queries
