02-09-2020, 11:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2017 Location: malaysia
Member: 2782332 Status: Offline Thanks Meter: 185 | Error Mar-Lx2 (Mar-L22b) i got error when trying to downgrade firmware this is the version before downgrade 2- i download file from easy-firmware (frp bypass MAR-LX2 9.1.0.241(c636) ).. i follow the procedure flashing without error but after finish flasing..happen only stuck in erecovery mode.. 3- i download another file (MAR-L22B 9.1.0.316(c636) ) After Flashing 0.reboot.apk then reboot phone go into system i turn off and flashing 1.app and got error Cust and stuck at 36% 4- i try to download full firmware version MAR-L22B 9.1.0.316(c636) got error at preas.img 5- after error flashing only shown this in fastboot mode 6-and now only after flash ( FRP BYPASS MAR-L22B 9.1.0.316)c636) 0.reboot.app only can go boot into inside system. need Team Or Any Expert Help Please.. |
02-10-2020, 06:22 | #5 (permalink) |
Member: 2782332 Status: Offline Thanks Meter: 185 | i have succefully make my phone alive and downgrade succefully to bypass frp.. current version is 9.1.0.316 1- need update firmware to MAR-L22B 9.1.0.316 2- download file to do it follow intryction.. 3- success ThankYou Team.. |
The Following User Says Thank You to kinryo For This Useful Post: |
02-14-2020, 08:44 | #7 (permalink) |
Member: 2782332 Status: Offline Thanks Meter: 185 | 1-FIRST YOU NEED MAKE YOUR PHONE ALIVE FIRST!! 2-If your verison is MAR-L21A(c431) Download full firmware MAR-L21A 9.1.0.317(c431) (HOW TO FLASH) 3-after extract full firmware and check inside folder dload, there got 3 zip..please extract all and follow the steps to flash 4-Flash 1.base_ptable.app(no reboot) 2.cust_ptable.app(no reboot) 3.preload_ptable.app(no reboot) 4.Cust.update.app(no reboot) 5.preload.update.app(no reboot) 6.base.update.app(Please Tick Reboot in Last) |
The Following 4 Users Say Thank You to kinryo For This Useful Post: |
02-14-2020, 10:03 | #9 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Quote:
excellent bro, successfully recovered the phone now whats procedure for downgrade ? | |
02-14-2020, 10:14 | #10 (permalink) |
Junior Member Join Date: Dec 2005
Member: 205806 Status: Offline Thanks Meter: 77 | when i try flash like you write i have like that Checking fastboot device.....OK Reading info.....OK Device Firmware: :Error: /preas/xxx not found in /product/hw_oem/MAR-L22B/par Checking needed files.....Not found Writing rescue image.....Failed: Extraction failed Operation {Flash APP Firmware} ID: D5FDE1B3F57A0ACF Elapsed time 00:12 -- Version 1.9.2 |
02-14-2020, 11:32 | #13 (permalink) | |
Member: 2782332 Status: Offline Thanks Meter: 185 | Quote:
Or maybe others..sure this can be recovery back..i just tested | |
