Error Mar-Lx2 (Mar-L22b) 1- i got error when trying to downgrade firmware this is the version before downgrade https://i.ibb.co/TvY3Mnk/mar-lx2-info-error-model.png 2- i download file from easy-firmware (frp bypass MAR-LX2 9.1.0.241(c636) ).. i follow the procedure flashing without error but after finish flasing..happen only stuck in erecovery mode.. 3- i download another file (MAR-L22B 9.1.0.316(c636) ) After Flashing 0.reboot.apk then reboot phone go into system i turn off and flashing 1.app and got error Cust and stuck at 36% 4- i try to download full firmware version MAR-L22B 9.1.0.316(c636) got error at preas.img https://i.ibb.co/kgt3nM9/preas-error.png 5- after error flashing only shown this in fastboot mode https://i.ibb.co/2s9TD0R/info-error-preas.png 6-and now only after flash ( FRP BYPASS MAR-L22B 9.1.0.316)c636) 0.reboot.app only can go boot into inside system. need Team Or Any Expert Help Please.. |
Need help please..!! |
Tuve un problema parecido ,logré solucionarlo háblame al mp para ver si lo solucionamos |
i have succesfully recover back by full firmware..now i retry downgrade to bypass frp again.. |
i have succefully make my phone alive and downgrade succefully to bypass frp.. current version is 9.1.0.316 1- need update firmware to MAR-L22B 9.1.0.316 2- download file to do it follow intryction.. 3- success ThankYou Team.. |
i have this same problem like you how you restore to stock rom ? |
1-FIRST YOU NEED MAKE YOUR PHONE ALIVE FIRST!! 2-If your verison is MAR-L21A(c431) Download full firmware MAR-L21A 9.1.0.317(c431) (HOW TO FLASH) 3-after extract full firmware and check inside folder dload, there got 3 zip..please extract all and follow the steps to flash 4-Flash 1.base_ptable.app(no reboot) 2.cust_ptable.app(no reboot) 3.preload_ptable.app(no reboot) 4.Cust.update.app(no reboot) 5.preload.update.app(no reboot) 6.base.update.app(Please Tick Reboot in Last) |
yes but i don't have idea what firmware been early |
excellent bro, successfully recovered the phone now whats procedure for downgrade ? |
when i try flash like you write i have like that Checking fastboot device.....OK Reading info.....OK Device Firmware: :Error: /preas/xxx not found in /product/hw_oem/MAR-L22B/par Checking needed files.....Not found Writing rescue image.....Failed: Extraction failed Operation {Flash APP Firmware} ID: D5FDE1B3F57A0ACF Elapsed time 00:12 -- Version 1.9.2 |
my software region is c636 is it downgrade possible |
Just write firmware 9.1.0.316 mar-l22b downgrade frp firmware..follow full.procedure..now will seccuess |
Or maybe others..sure this can be recovery back..i just tested |
Whats is your firmware version now??if lower than version 10..try Download frp bypass downgrade firmware for 9.1.0.316(c636) and follow all the steps |
And make sure you phone firmware version is same as 9.1.0.316(c636) You can do.upgrade first is the version is not this |
