Old 02-14-2020, 13:22   #16 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,949
still getting error
cant update 2.app
Flashing Block:sha256rsa
Flashing Block:crc
Flashing Block:cust_verlist
当前手机未处于升级模式状态!!!
FRP BYPASS HUAWEI MAR-XX2 9.1.0(C636).EF
Old 02-14-2020, 13:55   #17 (permalink)
Member: 2782332
Thanks Meter: 132
[QUOTE=Mr.3.;14013636]still getting error
cant update 2.app
Flashing Block:crc
当前手机未处于升级模式状态!!!
FRP BYPASS HUAWEI MAR-XX2 9.1.0(C636).EF[/QUOTE
If you get error..maybe your phone version is not 9.1..317(c636)..
First- please make sure your phone current firmware version is 9.1.0.316(c636)
Second you need download FRP Bypass MAR-L22B 9.1.0.316(C636).EF
Old 02-14-2020, 14:25   #18 (permalink)
Member: 2782332
Thanks Meter: 132
Or what is your model version exactly ??
I have done it in mar-l22b 9.1.0.325(c636)
Old 02-14-2020, 18:04   #19 (permalink)
Thanks Meter: 13,552
Originally Posted by baddog View Post
when i try flash like you write i have like that
checking fastboot device.....ok
reading info.....ok
device firmware: :error: /preas/xxx not found in /product/hw_oem/mar-l22b/par
checking needed files.....not found
writing rescue image.....failed: Extraction failed
operation {flash app firmware} id: D5fde1b3f57a0acf
elapsed time 00:12 -- version 1.9.2
move dload folder to desktop abd try again
Old 02-14-2020, 18:06   #20 (permalink)
Device MUST be on the same firmware as written on Downgrade file so if the downgrade file is 9.1.0.317(c636) then the device must be on 9.1.0.317(c636) .
Old 02-14-2020, 21:41   #21 (permalink)
Member: 205806
Thanks Meter: 77
still this same problem
Old 02-15-2020, 02:20   #22 (permalink)
Member: 2782332
Thanks Meter: 132
What u means still the same problem?
Old 02-15-2020, 05:56   #23 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,949
9.1.0.317(c636)this file not available at support ,only 316 available
Old 02-15-2020, 06:00   #24 (permalink)
Member: 2782332
Thanks Meter: 132
just flash 9.1.0.316
Old 02-15-2020, 06:13   #25 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,949
same error for this version too
EASY-FIRMWARE.COM
1 - Enter device to upgrade mode
2 - Select the file "1.APP" in EFT Pro and check all partitions from first until the "system" and uncheck all other parts and uncheck "Reboot on finish" option then flash
3 - Reboot the device to upgrade mode again
4 - Select the file "2.APP" and check all parts and uncheck "Reboot on finish" then flash
5 - Select the file "3.APP" and check all parts and uncheck "Reboot on finish" then flash
6 - Select the file "4.APP" and check all parts and uncheck "Reboot on finish" then flash
7 - Select the file "5.APP" and check all parts BUT check "Reboot on finish" then flash
2. success
3. done
4. fail in cust ver
Old 02-15-2020, 06:18   #26 (permalink)
Member: 2782332
Thanks Meter: 132
EASY-FIRMWARE.COM
2. success
3. done
4. fail in cust ver
i think u have download the wrong file
if version mar-l22b 9.1.0.316(c636)
should have
0.reboot.apk
1.apk
2.apk
3.apk
4.apk
5.apk
6.apk
Old 02-15-2020, 06:20   #27 (permalink)
Member: 2782332
Thanks Meter: 132
please download the proper firmware..you are using the old file..
please check this tittle in easyfirmware
The Following User Says Thank You to kinryo For This Useful Post:
Old 02-15-2020, 06:22   #28 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,949
should have
0.reboot.apk
1.apk
2.apk
3.apk
4.apk
5.apk
6.apk
i downloaded
Old 02-15-2020, 06:23   #29 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,949
ill post result bro ,thanks
Old 02-18-2020, 13:54   #30 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 3,949
sorry for late reply..
unlock done,,,special thanks to kinryo
The Following User Says Thank You to Mr.3. For This Useful Post:
Page generated in 0.21640 seconds with 7 queries
