03-22-2020, 09:51 | #1 (permalink) |
Product Manager Join Date: Feb 2016 Location: EFT Dongle
Member: 2536865 Status: Offline Sonork: 100.1584728 Thanks Meter: 21,229 | Fix: Bypassing downgrade protection.....Please contact support team. when facing such error in Huawei Downgrade Android 10 Process: Code: Bypassing downgrade protection.....Failed: writing failed, Please contact support team 1- Read info and check if your device model, android version and customization code are the same both on Device and Downgrade firmware. 2- If yes then move to second step which is to flash Stock Android 10 same as in your device via SD card or OTG then do repeat downgrade process again . 3- You can also try downgrading by flashing the AOD files via Flash Multi app files .. by adding files one by one A then O then D the put device in upgrade mode and flash .. 4- If not solved then make your own thread providing relevant images and logs and we will be glad to help . Best Regards! Easy Team |
The Following 13 Users Say Thank You to easy-team For This Useful Post: |
04-05-2020, 15:22 | #3 (permalink) |
No Life Poster Join Date: Sep 2006
Member: 346148 Status: Offline Thanks Meter: 27 | huawei nse-lx1 hi downgrading my huawei nse-lx1 fail "Checking fastboot device.....OK Reading info.....OK Device Model: SNE-LX1 Device Firmware: :SNE-LX1 10.0.0.170(C432E10R1P1) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....Security is not supported Operation {Reset FRP using server} ID: 910766B109FDDA72 Elapsed time 00:02 -- Version 1.9.6" Device Firmware: :Error: /preas/xxx not found in /product/hw_oem/SNE-L21/pare Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....OK Posting data to server.....OK Waiting for server response.....OK Unlocking device.....Security is not supported Operation {Reset FRP using server} ID: 8EEF810F6F23126F Elapsed time 06:24 -- Version 2.0" " so i flashed it "fix ' after flash phone name changed to nse-l21 and reboot from time to time and can t relmove frp can you help fix this issue thank |
04-10-2020, 20:43 | #4 (permalink) | |
Member: 346148 Status: Offline Thanks Meter: 27 | Quote:
is there a way to fix it. e recovey not work,no sd card update 5% BLOQUED | |
05-03-2020, 20:20 | #9 (permalink) |
Freak Poster Join Date: Dec 2014 Location: bahrain
Member: 2308999 Status: Offline Sonork: 100.1657583 Thanks Meter: 34 | Vog-l29 android 10 c185 Searching for upgrade port.....Detected {COM7} Target model [VOG-L29 10.0.0(C185)] Reading data from server.....OK Bypassing downgrade protection.....Failed: writing failed, Please contact support team Operation {Downgrade to reset FRP} ID: 61B2650B5DD6C464 DONE BY MULTI FILE FASHING METHORD Searching for upgrade port.....Detected {COM7} Connecting to device.....OK Start processing file [A.APP] 5,15 GB: Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [base_verlist.img].....OK Flashing [base_ver.img].....OK Flashing [package_type.img].....OK Flashing [hisiufs_gpt.img].....OK Flashing [xloader.img].....OK Flashing [fastboot.img].....OK Flashing [dts.img].....OK Flashing [dto.img].....OK Flashing [vector.img].....OK Flashing [fw_lpm3.img].....OK Flashing [hhee.img].....OK Flashing [vbmeta.img].....OK Flashing [teeos.img].....OK Flashing [trustfirmware.img].....OK Flashing [sensorhub.img].....OK Flashing [fw_hifi.img].....OK Flashing [kernel.img].....OK Flashing [modemnvm_update.img].....OK Flashing [modemnvm_cust.img].....OK Flashing [modem_driver.img].....OK Flashing [recovery_ramdisk.img].....OK Flashing [recovery_vendor.img].....OK Flashing [recovery_vbmeta.img].....OK Flashing [erecovery_kernel.img].....OK Flashing [erecovery_ramdisk.img].....OK Flashing [erecovery_vendor.img].....OK Flashing [erecovery_vbmeta.img].....OK Flashing [eng_vendor.img].....OK Flashing [eng_system.img].....OK Flashing [hdcp.img].....OK Flashing [cache.img].....OK Flashing [system.img].....OK Flashing [cust.img].....OK Flashing [isp_firmware.img].....OK Flashing [modem_fw.img].....OK Flashing [hisee_img.img].....OK Flashing [vendor.img].....OK Flashing [odm.img].....OK Flashing [product.img].....OK Flashing [preas.img].....OK Flashing [preavs.img].....OK Flashing [patch.img].....OK Flashing [userdata.img].....OK Flashing [ufsfw.img].....OK Start processing file [O.APP] 9 MB: Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [cust_verlist.img].....OK Flashing [cust_ver.img].....OK Flashing [package_type.img].....OK Flashing [ptable_cust.img].....OK Flashing [version.img].....OK Start processing file [D.APP] 340 MB: Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [preload_verlist.img].....OK Flashing [preload_ver.img].....OK Flashing [package_type.img].....OK Flashing [ptable_preload.img].....OK Flashing [preload.img].....OK Rebooting device.....OK Operation {Flash multi APP files} ID: 11E1C76D518FD0B9 Elapsed time 10:50 -- Version 2.2 |
05-04-2020, 16:42 | #10 (permalink) |
Freak Poster Join Date: Sep 2017 Location: Rawalpindi
Member: 2755459 Status: Offline Thanks Meter: 46 | Hi there all just last night I have bought the Eft pro dongle from a friend with 2 years activation username and password he give me I am putting it but it's asking for email and he don't know the email please help me brother |
07-08-2020, 21:22 | #11 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Tanzania
Member: 1825908 Status: Offline Sonork: juju Thanks Meter: 60 | P10 VTR-L29 dead after downgrade My phone VTR-L29, 9.1.0 EMUI 9.1 C185 after downgrade to 8.0.0 phone dead, i revive it by flashing board firmware... Then flashing the 9.1.0 phone alive again but unfortunatelly imei turn to "00000" and as i know there is no box support repair imei on android 9 untill i downgrade to 8.0 Anyone here will help me and apreciated |
07-09-2020, 12:45 | #12 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | Searching for upgrade port.....Detected {COM5} Target model [VOG-L04 10.0.0(C605)] Reading data from server.....OK Bypassing downgrade protection.....Failed: writing failed, Please contact support team Operation {Downgrade to reset FRP} ID: 519DA582210E2B07 Elapsed time 00:04 -- Version 3.1.2 |
07-10-2020, 08:10 | #13 (permalink) | |
Freak Poster Join Date: Aug 2015
Member: 2439409 Status: Offline Thanks Meter: 104 | Quote:
You can also try downgrading by flashing the AOD files via Flash Multi app files .. by adding files one by one A then O then D the put device in upgrade mode and flash | |
07-12-2020, 08:48 | #14 (permalink) | |
Member: 1825908 Status: Offline Sonork: juju Thanks Meter: 60 | Vtr-l29 Quote:
i found one downgrade firmware in FTP but when i flash phone dead. Where to get AOD and how to put phone in upgrade mode. Thanks in advance sir | |
07-12-2020, 08:52 | #15 (permalink) | |
Member: 1825908 Status: Offline Sonork: juju Thanks Meter: 60 | Quote:
i found one downgrade firmware in FTP but when i flash phone dead. Where to get AOD for this model and how to put phone in upgrade mode. Thanks in advance sir | |
