03-30-2019, 08:52 | #1 (permalink) |
Junior Member Join Date: Oct 2015
Member: 2473266 Status: Offline Thanks Meter: 4 | G935f U4 Frp and pattern remove with out data loss (Solved) Step 1 sboot flash successfully and done Frp with URT cable. But phone is not in menu i am receving exception handler red line. When i flash stock with home csc phone in menu with pattern lock. and frp is off. then i have make recovery to remove screen lock New. and flash recovery . eft . now phone is recovery password protected. and if i flash stock recovery again still recovery password protected. means recovery currupt. then i flash stock firmware with home csc then phone in menu with user pattern lock. Just need guidelines in second step. |
The Following User Says Thank You to Altaf Ahmad For This Useful Post: |
03-30-2019, 10:32 | #3 (permalink) |
Member: 2473266 Status: Offline Thanks Meter: 4 | G935f U4 solved Sir Solved Thank you eft team for quick response. Issue was G935F U4 Not showing on my exe. Just removed and reinstalled now i have solved my issue and pattern removed with the given link. |
