-   EFT Dongle (http://forum.gsmhosting.com/vbb/f1014/)
-   -   How to downgrade all huawei with easy firmware files (http://forum.gsmhosting.com/vbb/f1014/how-downgrade-all-huawei-easy-firmware-files-2739079/)
easy-team 12-03-2019 17:18
HOW TO DOWNGRADE ALL HUAWEI WITH EASY FIRMWARE FILES
Here's how to remove Google Account for all Huawei devices
By DOWNGRADE process .
If error comes out while flashing use this method:
The process of DOWNGRADE always fails with New Phone and New security Like Model P30 LITE
First, Easy Firmware team does not take any responsibility
The entire process is at your own risk (note that the method has been successfully tested)
The method is as follows: get the two firmware files for your device ( Downgrade and latest )
One same version and the same protection and the same guidance to download from HERE
And one Downgrade flash for your device the same model and the same guidance All files are collect to download from HERE
Now we have two flashes, one Dongred and one same version of the phone
We open EFT PRO
We go to the Huawei interface and identify the official flash that the same version of the device and protection and connect the phone to put Upgrade mod
We select the discs in the image and deselect the REBOOT AFTER FLASH and FASTBOOT TO UPGRDAE
To see the picture more clearly from HERE
https://4.top4top.net/p_1429ghkej1.png
Now the dongle flashes the discs that have been identified and stands on the Upgrade mode.
Now we come to EFT PRO and select the flash Downgrade that we downloaded and start flashing
Then the flashing ends and the dongride process is done successfully and now you can unzip the phone through the Safe Mode loophole
https://img.easy-firmware.com/images...2202736142.jpg
Repeat:
Easy Firmware team takes no responsibility
Original thread in here :
https://easy-firmware.com/index.php?...ticle&id=21351
validvalizadeh 12-04-2019 12:18
thanks bro very helpful solution :*
FrunzyGSM 12-04-2019 13:31
Not work for latest p30 lite 9.1.0.275 firmware!!!
easy-team 12-04-2019 14:44
Open your own thread and provide screen shots
mahtabansari 12-04-2019 17:49
you can see the video in this prosass
FrunzyGSM 12-05-2019 15:25
i use files from easyfirmware but for flashing use mrt, but i think there is not a problem,phone firmware is 9.1.0.275 C431 i have downloaded 9.1.0.275 from easyfirmware, and 9.1.0.215 frp file, i have load app from 9.1.0.275 check first 5 partition writed them without reboot, then load the app from 9.1.0.215 and press write and get error!!!
agentot 12-09-2019 15:08
i can confirm!
@frunzy have you found a solution?
br
ss
salama5 12-10-2019 10:01
hello
someone can confirm me if possibile or not
pedmarques 12-11-2019 00:20
p30 lite 9.1.0.275 any solution?
FrunzyGSM 12-11-2019 11:10
still no solution!!! only frp key $$$$$$
luyanda 12-11-2019 15:13
I Have same phone version i flash it now my phone is brick did you win your phone please share solution
lages_79 12-12-2019 08:40
video tutorials will be even better if included
matrix005 12-18-2019 02:56
Good Job. thanks for your attention
Abdulmobiles 12-19-2019 18:21
Thanks for Use full post.
abbotpk 12-20-2019 12:49
nova 3i downgrade
hello sir i need to know is it possible nova 3i ine-lx1r downgrade 9 to 8
Page generated in 0.28962 seconds with 5 queries
