i used this firmware : ELLE-L29B 9.1.0.185(C461E4R1P11) Tu flash C431 |
Thank you for the information Sent from my STK-L22 using Tapatalk |
Hello. There is an instruction how to lower Magic UI 3.0 (aka EMUI 10) to 9.1.0? There was a solution: About huawei flash file knowledge in mrt - MRTKEY Forum But I didn’t succeed :( Maybe someone will figure it out and explain? Am I doing something wrong? |
I can help in that matter,contact me if you need (other tool needed) |
The new firmware on Huawei p30 lite those not allow you retrieve IMEI and serial through Fastboot, anyone with another method ? Thanks |
hi i used new firmware (ELLE-L29B 9.1.0.185(C431E4R2P2)_Firmware_9.0.0_r3_EMUI9.1.0_05015RBQ ) for downgrad p30 elle-l29 to by passe frp but i have this error now this is the log Checking fastboot device.....OK Reading info.....OK Device Model: ELE-L29 Device Firmware: :ELE-L29 9.1.0.240(C431E4R2P2) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Checking needed files.....OK Writing image 1.....OK Writing image 2.....OK Writing image 3.....OK Switching to upgrade mode.....OK Waiting for Upgrade Mode port.....OK Connecting to device.....OK Start processing file [UPDATE.APP] 5,11 GB: Firmware version: ELE 9.1.0(OVS) Flashing [sha256rsa.img].....OK Flashing [crc.img].....OK Flashing [base_verlist.img].....OK Flashing [base_ver.img].....OK Flashing [package_type.img].....OK Flashing [hisiufs_gpt.img].....OK Flashing [xloader.img].....OK Flashing [fastboot.img].....OK Flashing [dts.img].....OK Flashing [dto.img].....OK Flashing [vector.img].....OK Flashing [fw_lpm3.img].....OK Flashing [hhee.img].....OK Flashing [vbmeta.img].....OK Flashing [teeos.img].....OK Flashing [trustfirmware.img].....OK Flashing [sensorhub.img].....OK Flashing [fw_hifi.img].....OK Flashing [kernel.img].....OK Flashing [modemnvm_update.img].....OK Flashing [modemnvm_cust.img].....OK Flashing [modem_driver.img].....OK Flashing [recovery_ramdisk.img].....OK Flashing [recovery_vendor.img].....OK Flashing [recovery_vbmeta.img].....OK Flashing [erecovery_kernel.img].....OK Flashing [erecovery_ramdisk.img].....OK Flashing [erecovery_vendor.img].....OK Flashing [erecovery_vbmeta.img].....OK Flashing [eng_vendor.img].....OK Flashing [eng_system.img].....OK Flashing [hdcp.img].....OK Flashing [cache.img].....OK Flashing [system.img].....OK Flashing [cust.img].....OK Flashing [isp_firmware.img].....OK Flashing [modem_fw.img].....OK Flashing [hisee_img.img].....OK Flashing [vendor.img].....OK Flashing [odm.img].....OK Flashing [product.img].....OK Flashing [preas.img].....Failed: Write failed Operation {Flash APP Firmware} ID: 0DF1507196BE081C Elapsed time 09:10 -- Version 1.8.2 |
create same phone's version verlist then reflash it |
Dear EFT Team. The instructions laid out here https://easy-firmware.com/index.php?...older&id=51509 do not work. The first 6 files are not flashed. Error on verlist. |
hi eft team, how to lower firmware ELE-L29 10.0.0.168 (C10) to 9.1 constantly there is an error when lowering?the instruction from mrt is not complete, everything is done as indicated |
hi, vog-al10 downgrade files not working The instructions laid out here The instructions laid out here https://easy-firmware.com/index.php?...file&id=179411 do not work. The first 6 files are not flashed. Error on verlist. do not work. The first 3 files are working show Error on verlist. |
Which file u flashed and u have success with. Sent from my iPhone using Tapatalk |
[QUOTE=easy-team;13919123[/QUOTE] you have been hacked? |
What a fake post ... |
Checking fastboot device.....OK Reading info.....OK Device Model: HMA-L29 Device Firmware: :HMA-L29 9.1.0.346(C432E10R1P16) Device FB Lock: LOCKED Device USER Lock: LOCKED Device Lock: locked Waiting for server.....OK Reading data.....Security is not supported Operation {Flash APP Firmware} ID: 6A2BD4B2B8CE6119 Elapsed time 00:03 -- Version 1.9.1 |
