Old 12-03-2019, 17:18   #1 (permalink)
Thanks Meter: 13,255
How to downgrade all huawei with easy firmware files
HOW TO DOWNGRADE ALL HUAWEI WITH EASY FIRMWARE FILES
Here's how to remove Google Account for all Huawei devices
By DOWNGRADE process .
If error comes out while flashing use this method:
The process of DOWNGRADE always fails with New Phone and New security Like Model P30 LITE
First, Easy Firmware team does not take any responsibility
The entire process is at your own risk (note that the method has been successfully tested)
The method is as follows: get the two firmware files for your device ( Downgrade and latest )
One same version and the same protection and the same guidance to download from HERE
And one Downgrade flash for your device the same model and the same guidance All files are collect to download from HERE
Now we have two flashes, one Dongred and one same version of the phone
We open EFT PRO
We go to the Huawei interface and identify the official flash that the same version of the device and protection and connect the phone to put Upgrade mod
We select the discs in the image and deselect the REBOOT AFTER FLASH and FASTBOOT TO UPGRDAE
To see the picture more clearly from HERE
Now the dongle flashes the discs that have been identified and stands on the Upgrade mode.
Now we come to EFT PRO and select the flash Downgrade that we downloaded and start flashing
Then the flashing ends and the dongride process is done successfully and now you can unzip the phone through the Safe Mode loophole
Repeat:
Easy Firmware team takes no responsibility
Original thread in here :
https://easy-firmware.com/index.php?...ticle&id=21351
The Following 19 Users Say Thank You to easy-team For This Useful Post:
Old 12-04-2019, 12:18   #2 (permalink)
Member: 2927435
Sonork: valid
thanks bro very helpful solution :*
The Following User Says Thank You to validvalizadeh For This Useful Post:
Old 12-04-2019, 13:31   #3 (permalink)
Member: 56948
Thanks Meter: 10
Not work for latest p30 lite 9.1.0.275 firmware!!!
Old 12-04-2019, 14:44   #4 (permalink)
Open your own thread and provide screen shots
Old 12-04-2019, 17:49   #5 (permalink)
Member: 2253249
Thanks Meter: 23
you can see the video in this prosass
Old 12-05-2019, 15:25   #6 (permalink)
Member: 56948
Thanks Meter: 10
i use files from easyfirmware but for flashing use mrt, but i think there is not a problem,phone firmware is 9.1.0.275 C431 i have downloaded 9.1.0.275 from easyfirmware, and 9.1.0.215 frp file, i have load app from 9.1.0.275 check first 5 partition writed them without reboot, then load the app from 9.1.0.215 and press write and get error!!!
The Following User Says Thank You to FrunzyGSM For This Useful Post:
Old 12-09-2019, 15:08   #7 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 197
i can confirm!
@frunzy have you found a solution?
br
ss
Old 12-10-2019, 10:01   #8 (permalink)
Member: 290242
hello
someone can confirm me if possibile or not
Old 12-11-2019, 00:20   #9 (permalink)
Member: 161389
Thanks Meter: 5
p30 lite 9.1.0.275 any solution?
Old 12-11-2019, 11:10   #10 (permalink)
Member: 56948
Thanks Meter: 10
still no solution!!! only frp key $$$$$$
Old 12-11-2019, 15:13   #11 (permalink)
Member: 430612
Thanks Meter: 268
I Have same phone version i flash it now my phone is brick did you win your phone please share solution
Old 12-12-2019, 08:40   #12 (permalink)
Member: 636569
Thanks Meter: 181
video tutorials will be even better if included
Old 12-18-2019, 02:56   #13 (permalink)
Member: 2377510
Sonork: 1683039
Good Job. thanks for your attention
Old 12-19-2019, 18:21   #14 (permalink)
Member: 2922285
Thanks for Use full post.
Old 12-20-2019, 12:49   #15 (permalink)
Member: 2688875
nova 3i downgrade
hello sir i need to know is it possible nova 3i ine-lx1r downgrade 9 to 8
Page generated in 0.20741 seconds with 7 queries
