Old 12-23-2019, 22:22   #16 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 64
Hello team .i need this downgrade file MAR-LX1M 9.1.0 624(C185)
Old 12-24-2019, 10:36   #17 (permalink)
Mohammed Aamri's Avatar
Member: 2536614
Thanks Meter: 2,608
Check here :
MAR-LX1M
BR,
Mohammed Aamri
Old 12-25-2019, 16:18   #18 (permalink)
Member: 2076643
Sonork: 100.1650096
Thanks Meter: 64
Originally Posted by Mohammed Aamri View Post
Check here :
MAR-LX1M
BR,
Mohammed Aamri
Already downloaded but not the same I NEED THIS version https://www.youtube.com/watch?v=OO8n0FaHaug&t=125s
Old 12-28-2019, 23:21   #19 (permalink)
Member: 529749
Thanks Meter: 5
thinks great team eft the best
Old 12-30-2019, 13:55   #20 (permalink)
Member: 430612
Thanks Meter: 268
p30 lite 9.1.0.275 any solution?
Old 01-01-2020, 11:12   #21 (permalink)
Member: 328688
Thanks Meter: 1,564
this one can be downgrade it r not
Device Model: ‪MAR-LX1M‬
System: ‪MAR-L01MEA 9.1.0.275(C316E7R1P5)
Old 01-02-2020, 20:17   #22 (permalink)
Member: 2211814
nope sir half bricked phone two times .writing withn errors
Old 01-02-2020, 20:55   #23 (permalink)
Member: 2211814
Originally Posted by FrunzyGSM View Post
i use files from easyfirmware but for flashing use mrt, but i think there is not a problem,phone firmware is 9.1.0.275 C431 i have downloaded 9.1.0.275 from easyfirmware, and 9.1.0.215 frp file, i have load app from 9.1.0.275 check first 5 partition writed them without reboot, then load the app from 9.1.0.215 and press write and get error!!!
done same process but not having any chance no solution?
Old 01-03-2020, 01:20   #24 (permalink)
Member: 2849041
Thanks Meter: 10
About P30 lite
Yes it can work i tested 100%
2- can work for all devices ( i tested on p20 lite need unlock and its has last security i did same method and its work 100% )
Thanks for EFT TEAM 🙏🏻 Full Support 🙏🏻
Old 01-03-2020, 15:14   #25 (permalink)
Member: 1733156
Thanks Meter: 2
p30 with 275ver not working also HRY-LX1 on 284ver not working
Old 01-03-2020, 16:50   #26 (permalink)
Member: 1733156
Thanks Meter: 2
HRY-LX1 on 284ver WORK IN 262 version firmware!!! thk EFT bro!
Old 01-13-2020, 12:01   #27 (permalink)
Ali idrees's Avatar
Member: 1851480
Sonork: 100.1660354
Thanks Meter: 142
need this firmware
Rne-l21 8.0.0.345(c185custc185d1)
Old 01-14-2020, 06:24   #28 (permalink)
Member: 430612
Thanks Meter: 268
p30 lite 9.1.0.317 C316 any solution?
Old 01-16-2020, 08:14   #29 (permalink)
Member: 2123463
Sonork: 100.1652545
Thanks Meter: 22
Mention PLz first we have to select which file downgrade or upgrade?
Originally Posted by easy-team View Post
HOW TO DOWNGRADE ALL HUAWEI WITH EASY FIRMWARE FILES
Here's how to remove Google Account for all Huawei devices
By DOWNGRADE process .
If error comes out while flashing use this method:
The process of DOWNGRADE always fails with New Phone and New security Like Model P30 LITE
First, Easy Firmware team does not take any responsibility
The entire process is at your own risk (note that the method has been successfully tested)
The method is as follows: get the two firmware files for your device ( Downgrade and latest )
One same version and the same protection and the same guidance to download from HERE
And one Downgrade flash for your device the same model and the same guidance All files are collect to download from HERE
Now we have two flashes, one Dongred and one same version of the phone
We open EFT PRO
We go to the Huawei interface and identify the official flash that the same version of the device and protection and connect the phone to put Upgrade mod
We select the discs in the image and deselect the REBOOT AFTER FLASH and FASTBOOT TO UPGRDAE
To see the picture more clearly from HERE
Now the dongle flashes the discs that have been identified and stands on the Upgrade mode.
Now we come to EFT PRO and select the flash Downgrade that we downloaded and start flashing
Then the flashing ends and the dongride process is done successfully and now you can unzip the phone through the Safe Mode loophole
Repeat:
Easy Firmware team takes no responsibility
Original thread in here :
https://easy-firmware.com/index.php?...ticle&id=21351
Mention PLz..... first we have to select which file downgrade or upgrade?
you mentioned that we must have one same version file and second downgrade file
what file you selected in first step
I-E
SHA256RSA
CRC
BASE_VERLIST
BASE_VER
PAKAGE_TYPE-----------------> is this downgrade file or same version file???
Old 01-20-2020, 12:00   #30 (permalink)
Member: 2081857
Sonork: 1000.2
Thanks Meter: 35
hi best team
i have purchased new eft dongle i want to remove frp from huawei p30 with downgrad method
Checking fastboot device.....OK
Reading info.....OK
Device Model: ELE-L29
Device Firmware: :ELE-L29 9.1.0.240(C431E4R2P2)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Operation {Read info} ID: 58C0B540C90D626D1C29D68321107EA2
Elapsed time 00:01 -- Version 1.7.9.1
i used this firmware :Huawei P30 ELE-L29 hw cea ELLE-L29B 9.1.0.185(C461E4R1P11) Firmware 9.0.0 r3 EMUI9.1.0 05015SYE
with eft it say security not supported
or i make mistake
any hope to guide me step by step to use this new dongle
emergency
Page generated in 0.21658 seconds with 7 queries
