Old 01-22-2020, 22:48   #31 (permalink)
Member: 686560
Thanks Meter: 54
Originally Posted by bibi018 View Post
hi best team
i have purchased new eft dongle i want to remove frp from huawei p30 with downgrad method
Checking fastboot device.....OK
Reading info.....OK
Device Model: ELE-L29
Device Firmware: :ELE-L29 9.1.0.240(C431E4R2P2)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Operation {Read info} ID: 58C0B540C90D626D1C29D68321107EA2
Elapsed time 00:01 -- Version 1.7.9.1
i used this firmware :Huawei P30 ELE-L29 hw cea ELLE-L29B 9.1.0.185(C461E4R1P11) Firmware 9.0.0 r3 EMUI9.1.0 05015SYE
with eft it say security not supported
or i make mistake
any hope to guide me step by step to use this new dongle
emergency
Device Firmware: :ELE-L299.1.0.240(C431E4R2P2)
i used this firmware : ELLE-L29B 9.1.0.185(C461E4R1P11)
Tu flash C431
The Following User Says Thank You to serpas007 For This Useful Post:
Old 01-23-2020, 03:21   #32 (permalink)
Member: 985857
Sonork: 100.1677137
Thanks Meter: 163
Thank you for the information
Sent from my STK-L22 using Tapatalk
Old 01-23-2020, 14:00   #33 (permalink)
Mbm
Member: 50928
Thanks Meter: 2
Hello. There is an instruction how to lower Magic UI 3.0 (aka EMUI 10) to 9.1.0? There was a solution: About huawei flash file knowledge in mrt - MRTKEY Forum But I didnít succeed Maybe someone will figure it out and explain? Am I doing something wrong?
Old 01-27-2020, 23:40   #34 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,018
I can help in that matter,contact me if you need (other tool needed)
Old 01-28-2020, 17:16   #35 (permalink)
Member: 1327023
The new firmware on Huawei p30 lite those not allow you retrieve IMEI and serial through Fastboot, anyone with another method ? Thanks
Old 01-29-2020, 09:58   #36 (permalink)
Member: 2081857
Sonork: 1000.2
Thanks Meter: 35
hi i used new firmware (ELLE-L29B 9.1.0.185(C431E4R2P2)_Firmware_9.0.0_r3_EMUI9.1.0_05015RBQ ) for downgrad p30 elle-l29 to by passe frp but i have this error now
this is the log
Reading info.....OK
Device Lock: locked
Checking needed files.....OK
Writing image 1.....OK
Writing image 2.....OK
Writing image 3.....OK
Switching to upgrade mode.....OK
Waiting for Upgrade Mode port.....OK
Connecting to device.....OK
Start processing file [UPDATE.APP] 5,11 GB:
Firmware version: ELE 9.1.0(OVS)
Flashing [sha256rsa.img].....OK
Flashing [crc.img].....OK
Flashing [base_verlist.img].....OK
Flashing [base_ver.img].....OK
Flashing [package_type.img].....OK
Flashing [hisiufs_gpt.img].....OK
Flashing [xloader.img].....OK
Flashing [fastboot.img].....OK
Flashing [dts.img].....OK
Flashing [dto.img].....OK
Flashing [vector.img].....OK
Flashing [fw_lpm3.img].....OK
Flashing [hhee.img].....OK
Flashing [vbmeta.img].....OK
Flashing [teeos.img].....OK
Flashing [trustfirmware.img].....OK
Flashing [sensorhub.img].....OK
Flashing [fw_hifi.img].....OK
Flashing [kernel.img].....OK
Flashing [modemnvm_update.img].....OK
Flashing [modemnvm_cust.img].....OK
Flashing [modem_driver.img].....OK
Flashing [recovery_ramdisk.img].....OK
Flashing [recovery_vendor.img].....OK
Flashing [recovery_vbmeta.img].....OK
Flashing [erecovery_kernel.img].....OK
Flashing [erecovery_ramdisk.img].....OK
Flashing [erecovery_vendor.img].....OK
Flashing [erecovery_vbmeta.img].....OK
Flashing [eng_vendor.img].....OK
Flashing [eng_system.img].....OK
Flashing [hdcp.img].....OK
Flashing [cache.img].....OK
Flashing [system.img].....OK
Flashing [cust.img].....OK
Flashing [isp_firmware.img].....OK
Flashing [modem_fw.img].....OK
Flashing [hisee_img.img].....OK
Flashing [vendor.img].....OK
Flashing [odm.img].....OK
Flashing [product.img].....OK
Flashing [preas.img].....Failed: Write failed
Operation {Flash APP Firmware} ID: 0DF1507196BE081C
Elapsed time 09:10 -- Version 1.8.2
Old 01-29-2020, 13:45   #37 (permalink)
jawad8305's Avatar
Member: 198621
Sonork: 100.1591649
Thanks Meter: 1,018
create same phone's version verlist then reflash it
Old 02-01-2020, 11:34   #38 (permalink)
Mbm
Member: 50928
Thanks Meter: 2
Dear EFT Team. The instructions laid out here https://easy-firmware.com/index.php?...older&id=51509 do not work. The first 6 files are not flashed. Error on verlist.
Old 02-02-2020, 06:27   #39 (permalink)
Member: 2660252
hi eft team, how to lower firmware ELE-L29 10.0.0.168 (C10) to 9.1 constantly there is an error when lowering?the instruction from mrt is not complete, everything is done as indicated
Old 02-02-2020, 10:25   #40 (permalink)
Member: 115573
Thanks Meter: 83
hi,
vog-al10 downgrade files not working
The instructions laid out here The instructions laid out here https://easy-firmware.com/index.php?...file&id=179411 do not work. The first 6 files are not flashed. Error on verlist. do not work. The first 3 files are working show Error on verlist.
Old 02-02-2020, 10:56   #41 (permalink)
princemeedo's Avatar
Member: 2737570
Thanks Meter: 112
Originally Posted by haddadwork2017 View Post
Yes it can work i tested 100%
2- can work for all devices ( i tested on p20 lite need unlock and its has last security i did same method and its work 100% )
Thanks for EFT TEAM Full Support
Which file u flashed and u have success with.
Sent from my iPhone using Tapatalk
Old 02-08-2020, 06:46   #42 (permalink)
Member: 2945216
Thanks Meter: 7
[QUOTE=easy-team;13919123[/QUOTE]
you have been hacked?
Old 02-08-2020, 08:46   #43 (permalink)
Member: 2786211
Thanks Meter: 4
What a fake post ...
Old 02-08-2020, 16:11   #44 (permalink)
Member: 2199313
Reading info.....OK
Device Model: HMA-L29
Device Firmware: :HMA-L29 9.1.0.346(C432E10R1P16)
Device Lock: locked
Waiting for server.....OK
Reading data.....Security is not supported
Operation {Flash APP Firmware} ID: 6A2BD4B2B8CE6119
Elapsed time 00:03 -- Version 1.9.1
Page generated in 0.30273 seconds with 7 queries
