06-10-2018, 18:12 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2696825 Status: Offline Thanks Meter: 6 | How To Remove J7 Prime Lockscreen FRP ON, without Data Loss FRP Is ON, And How to Download exact Same Version of Firmware And How to Remove FRP and Lockscreen without Data loss... |
06-10-2018, 19:04 | #3 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2616438 Status: Offline Thanks Meter: 147 | To know your exact firmware just go to recovery mode and check yoor device firmware G610f have two different sboot files "G610f "and "G610fd" Which can be identified also from device firmware G610fxx or G610fdd To remove lockscreen you should have frp OFF To turn frp OFF you should apply Emmc Reset Frp via uart cable If device is 7.0 you should flash suitable 6.0.1 sboot from EFT support or from combination in order to get success in reset frp operation This process of reset frp via uart cable will not delete your data After frp is OFF Now you need to remove lockscreen To apply this you need recovery.img from same firmware of device You can find some in eft support or get from firmware.mobi Then create a custom recovery from make recovery delete lockscreen Then flash the obtained recovery.eft file The device will reboot with no lockscreen You will find that the device is with no launcher touchwiz to fix that Just sign in with a samsung to add accounts in settings Then go to this website https://findmymobile.samsung.com Sign in with same account and apply remove locks Now reflash device again with same recovery and system of the firmware available on device You are done Last edited by wadda7o; 06-10-2018 at 19:13. |
The Following 3 Users Say Thank You to wadda7o For This Useful Post: |
