htc ONE A9 flashing problem 2 Attachment(s) I have HTC One currently not show CID, bootloader unlocked, S-On I failed to flash, there is TWR inside ,here is details fastboot oem writesecureflag 3 ... FAILED (remote: unknown command) finished. total time: 0.014s fastboot getvar all (bootloader) version:0.5 (bootloader) ramdump-mode:false (bootloader) variant:MTP eMMC (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) max-download-size: 0x20000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x10000000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x29b000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0xc6000000 (bootloader) serialno:HT63GBE00538 all: finished. total time: 0.075s |
battery low 4% , it must be at least 30% |
No cid 1 Attachment(s) Quote:
here is attached file after flash with battery 80% |
Read full info in fastboot mode and post result |
(bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) max-download-size:0x20000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x10000000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x29b000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0xc6000000 (bootloader) serialno:HT63GBE00538 all: Execution time is 239(ms) (bootloader) ramdump-mode:false (bootloader) variant:MTP eMMC (bootloader) secure:yes Is this file fit for this phone OTA_HIA_AERO_UL_N70_SENSE80GP_ATT_MR_NA_Gen_Unlock _2.18.617.1-1.57.617.60_release_493556mv4q5xb4fbi8qvyk.zip |
till now no help from the team?? |
... OKAY Execution time is 22(ms) imei: 352636075288378 Execution time is 1(s) FAILunknown command getvar:modelid FAILED (remote: unknown command) Execution time is 2(ms) FAILunknown command getvar:cidnum FAILED (remote: unknown command) Execution time is 2(ms) sending 'zip'... (129503 KB) OKAY writing 'zip'... (bootloader) HOSD CL#882219 (bootloader) ERR Model ID not matched (bootloader) ERR [SD_UPDATE_ERR] MODEL ID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 10 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP signature checking failed... (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 10 (bootloader) end@Done sending time = 8.511 secs FAIL10 RU_MODELID_FAIL modelid in android-info mismatched FAILED (remote: 10 RU_MODELID_FAIL modelid in android-info mismatched ) Execution time is 15(s) rebooting... Execution time is 2(ms) |
