05-27-2020, 15:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,806 | Huawei Honor 8S KSA-LX9 frp remove done test point with powered off phone press start frp remove from eft exe connect test points then usb cable |
The Following 5 Users Say Thank You to profkefah For This Useful Post: |
08-27-2022, 20:01 | #4 (permalink) |
No Life Poster Join Date: Oct 2014 Location: Bangladesh
Member: 2274875 Status: Offline Sonork: ? Thanks Meter: 298 | Download And Extract All Frp File And Tools Install MTK USB Driver (if have Installed Before Then Skip This Step) Open Smart Phone Flash Tools Now Click Choose Load Scatter File From FRp File After Load FRP Scatter File Now Move To Format TAB And Select Manual Format Flash And Open Frp Address Text file from frp file and put the address code in manual format flash and hit start button Now Power off Your Smart Phone And Then Insert USB Cable To You Computer Once Boot Detected you Will Be Seen Format Ok And That’s mean Your Successfully Reset Frp Lock |
The Following User Says Thank You to the boss atik For This Useful Post: |
