Old 02-11-2020, 21:28   #1 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
Exclamation HUAWEI Id on p30 ELE-AL00 9.1.0(C00) Downgrade Firmware For Bypass Huawei Id
After flashing, Use safe mode method to Huawei Id. Important: Use this firmware at your own Risk!
Phone does not enter safe mode (not in the menu at least)
No codes work from emergency
What is the safe mode sollution?
Talkback is 7.2 version.... so no bypass either
ELLE-AL00B 9.1.0.162(C00E160R2P1)_Firmware_9.1.0_r1_EMUI9.1.0
Old 02-11-2020, 22:17   #2 (permalink)
Thanks Meter: 13,555
You must format device in recovery mode and then the safemode will show up , did u do that ?
Old 02-12-2020, 12:14   #3 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
Yes, I followed all the videos on youtube.
I wrote the downgrade firmware : first I tried only the .app from the base folder, then I wrote the cust .app also but no difference.
I hard reset it, then I choose Safe mode. It goes to safe mode (coz it`s written down left) but It aks for wifi and Huawei ID.
after hardreset, when I choose safe mode:
Old 02-12-2020, 12:24   #4 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
Fastboot info:
Old 02-12-2020, 17:35   #5 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 59
Originally Posted by tintome View Post
Fastboot info:
I am in the same looking for solution for this model with huawei id.
Old 02-13-2020, 00:46   #6 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
Well, do the "safe mode" bypass work with your phone ?
Old 02-13-2020, 22:47   #7 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 59
It does not work, does not enter the phone menu.
Old 02-13-2020, 23:58   #8 (permalink)
safina gsm's Avatar
Member: 2906511
Thanks Meter: 75
maybe you can try lower version by sd card
you won't lose any thing but be careful about model and such info
Old 02-14-2020, 05:48   #9 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 59
I have tried to do a version reduction but I always have an error in the update.
Old 02-14-2020, 18:49   #10 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
I can`t find any older than 162 version for ELE-AL00
My question is still : how come the safe mode bypass works for some ppl and for me it does not work?
I`m guessing it works considering it`s on the FTP server named downgrade for Huawei ID
Old 02-14-2020, 19:03   #11 (permalink)
xtreme's Avatar
Member: 48518
Sonork: 100.113013
Thanks Meter: 116
Safe mode trick only works when mobile have Frp,
this method dont work on huawei id locked.
Old 02-14-2020, 19:57   #12 (permalink)
Member: 731353
Thanks Meter: 174
if fail buy code bro..prices down,,check ourself on unlock sites
Old 02-14-2020, 20:26   #13 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
It` HUAWEI ID , not frp
Anyways, my issue was about ELE-AL00 9.1.0(C00) Downgrade Firmware For Bypass Huawei Id ... Did anyone used this and it worked?
https://easy-firmware.com/index.php?...file&id=178601
Old 02-14-2020, 21:53   #14 (permalink)
Member: 120579
Sonork: 100.1676046
Thanks Meter: 106
Can anybody tell me how to bypass ?
Video is not conclusive for this version. It`s badly named (file 2 is actually the last step)
https://mega.nz/#F!zfwzDAyR!j33Ye_Up...zzjFA!7fgHxSKK
Old 02-15-2020, 02:18   #15 (permalink)
Member: 2782332
Thanks Meter: 132
File 1 how many gb size ??and file 2 how many ??
No instructions inside?
Page generated in 0.36025 seconds with 7 queries
