Old 02-13-2020, 21:37   #1 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 60
huawei p30 pro VOG-AL10 huawei id?
I have this Huawei Vog-AL10 with Huawei ID and I need to remove the Huawei account.
He downloaded the firmware to download the file for downgrade and remove the Huewei account, but since I see 3 folders with several application files, I need the necessary instructions to avoid mistakes.
If you have a clearer manual than the one that is available or any video available with the process, I appreciate it, which I don't want to make a mistake.
Old 02-14-2020, 12:50   #2 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 157
https://easy-firmware.com/index.php?...file&id=179411
Old 02-14-2020, 13:30   #3 (permalink)
Member: 2782332
Thanks Meter: 139
You only.post model.info..but no firmware version..
How can we give tou suggestions ??
The Following User Says Thank You to kinryo For This Useful Post:
Old 02-14-2020, 17:01   #4 (permalink)
Thanks Meter: 13,822
Provide full info via fastboot
Old 02-15-2020, 15:16   #5 (permalink)
Member: 115573
Thanks Meter: 83
vog-al10 id bypass
Checking fastboot device.....OK
Reading info.....OK
Device Model: VOG-AL10
Device Firmware: :VOG-AL10 10.0.0.188(C00E85R1P8)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: locked
Operation {Read info} ID: F405A7ACC788DA00
Elapsed time 00:00 -- Version 1.9.3
thx
Old 02-15-2020, 16:13   #6 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 60
Originally Posted by solgeo View Post
I mean how the downgrade friend is done, because within that same files it contains multiple app files.
Old 02-17-2020, 12:01   #7 (permalink)
Member: 115573
Thanks Meter: 83
Originally Posted by okbadz View Post
vog-al10 id bypass
Reading info.....OK
Device Lock: locked
thx
huawei id remove success
i used VOG-AL00 for my VOG-AL10
successfully downgraded
after i use https://easy-firmware.com/index.php?...file&id=179411
with useful guide in. for finish. just corret guide in folder "STEP3" is
atached
File Type: txt 刷机教程,必看!.txt (666 Bytes, 51 views)
Old 02-18-2020, 09:46   #8 (permalink)
Member: 2397029
Thanks Meter: 33
atached
Firmware for eft user free or paid?
Old 03-13-2020, 09:56   #9 (permalink)
Member: 2438061
Sonork: 1668258:videle.gsm
Thanks Meter: 4
hy, i can remove huawei id ?
i tried to write this firmware and it failed
https://easy-firmware.com/index.php?...file&id=179514
Reading info.....OK
Device Model: VOG-AL00
Device Firmware: :VOG-AL00 10.0.0.188(C00E85R2P8)
Device Lock: locked
Operation {Read info} ID: 488E840D14D08368
Elapsed time 00:00 -- Version 1.9.6
Old 03-13-2020, 20:56   #10 (permalink)
Soon via EFT PRO .....
Old 03-26-2020, 08:35   #11 (permalink)
Member: 2438061
Thanks Meter: 4
hy, solution for huawei id remove?
Reading info.....OK
Device Lock: locked
Old 03-26-2020, 10:26   #12 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 157
Reading info.....OK
Device Lock: locked
hello
today just paid solution
Its possible . but not free (
Page generated in 0.37874 seconds with 8 queries
